1939 el installing clutch parts
  • JOHNNYJET
    • Jul 2025
    • 4
    1939 el installing clutch parts and pictures or advice would be helpful , having problem deciphering the palmer book
  • dukekleman
    • Jul 2022
    • 596
    Johnny,
    You mentioned you have Palmers book. It has the information you need to perform this service other than photos showing the tools required for proper installation.
    Here are some photos of a recent service of a 1939 EL I did for a friend. IMG_20250519_181947814.jpg
    Bar required for proper torque.
    Tooling required for torquing in step 1
    Tooling required for next torquing sequence.
    I hope these images help you achieve proper clutch assembly and operation.
    Duke Kleman
    • JOHNNYJET
      • Jul 2025
      • 4
      Thanks for the pictures, i have a tool for the clutch hub nut and the spring tension nut, but your tool looking better where did you get it
      also is the vent tube suppose to turn down like the picture,
      i used the original springs, but the ones i ordered are much longer
      so should i set the spring tension at 3/8" for the original springs or use the longer springs
      thank you for the pictures it very help full
      john
      • dukekleman
        • Jul 2022
        • 596
        John,
        Some of my tooling is after market and some I machined and made myself. Here's a few photos I took for you.
        Harley Davidson had a service bulletin regarding pressure plate spring .
        I typically set the preload @ or around 0.410". I base my setting off the stack height, math and pressure measured on each spring in my spring tester.
        In the photo above, you see the dimensional difference visually with the one on the far right.
        The chain oil director on the end of the crankcase breather should be positioned at the 6 O'clock position. There are reasons for this positioning.
        I hope this helps,
        ​​​​​​​Duke Kleman
