47 FL Springer?
  • uroford
    • Sep 2025
    • 7
    47 FL Springer?
    Just getting around to putting together this springer that I got with a basket case some 40 odd years ago, and wondering what I have here. It's an offset but I had to drill out front and rear to fit big twin rocker studs. I put in a v-twin timkin bearing kit, 24-
  • uroford
    • Sep 2025
    • 7
    Sorry, guess I fat fingered it before it was finished. 24-0230 and I've got about 1/2 in. down to the stem top. With the tree and top nut I need another 1/2 leaving me about an inch short! The neck with cups is 7 in. and the stem 7 3/4 without the bottom cone washer. I know the timkins stack up higher than the ball bearings, but not an inch. Is there a way around this?
    Steve Radz
    This gallery has 4 photos.
      • 2024
      Can you show a picture of the main brace of the rigid leg looking up from the bottom. The 13 front spring fork is not for an offset. An off set would have a milled 15, milled 16 or 17, 18. Needing to drill out the rocker hole holes suggests to me that it is originally a WL front end.
      Jerry
        • 4790
        Your lower bearing needs to NOT be on top of the centering cone that needs to be removed before you start.. And most of the issue is poorly made aftermarket junk.
        • uroford
          • Sep 2025
          • 7
          Here are a couple more shots, looks like the bottom has been smoothed.
          This gallery has 3 photos.
          • uroford
            • Sep 2025
            • 7
            So, I need an offset spring fork and a new stem to make this work?
              • 2024
              Your springer is not am offset. It has the main brace of an inline. It has been bent to offset the top.
              Jerry
                • 2024
                DSC03868.JPG DSC03867.JPG Shown here is the difference between the main brace on an offset springer (top) versus an inline springer main brace (bottom). For and offset they tilted the top of the stem to the rear they also moved the bottom of the stem forward.
                Jerry
                • uroford
                  • Sep 2025
                  • 7
                  Thanks Jerry,
                  Do you think this may be a WL that someone tweaked in a press to make it an offset?
                  • uroford
                    • Sep 2025
                    • 7
                    Sorry, didn't see you already posted the answer
