I have a 41 ULH with the correct spotlights and Hollywood bars. The right side of the bars are drilled for a headlight hi beam switch. I was told that’s for the spotlights and want to verify this. I didn’t think a switch would be standard because of the toggle switches incorporated into the spotlights. Thanks in advance.
Spotlight Switch
Both my 47EL and 48EL have the high beam switch let side and spot light switch right side. Both also have the toggles on the light itself.
https://www.hydra-glide.net/phpBB3/k.../article?k=524
This is a link to the wiring diagram for a 47'
I installed the switch over the existing holes (was drilled for a button, maybe a kill switch). The existing holes were at about 10 o’clock on the right side of the bars looking from the right side inward. Is this the correct location or would the switch been mounted underneath similar to the high beam dimmer? Either way I had to cover the existing holes and didn’t really have a choice. Thanks for the input.
If it was drilled for a button it was likely police bars set up for a Speedometer hand lock. Pursuit light switches were mounted underneath the bar.Robbie Knight Amca #2736
