Another frame id post
  • FLFD7
    • Feb 2021
    • 739
    Hola Harley experts, Indian guy here and I’m a knucklehead about Knuckleheads. In my father’s stash is this Knucklehead frame, and I’m looking to find out what year it’s from. This’ll be a couple posts long cause of all the photos. A general overview…
    Some detail casting numbers to follow…
    • 2024
    Frame is 1940 and the front end is newer as is the rocker clutch bracket. With all the gorilla work around the neck it is remotely possible to be an early 1941 induced rack frame but with no frame ground tab I doubt it.
    Jerry
    • FLFD7
      • Feb 2021
      • 739
      Rear axle plate, left side…
      XE 7 4
      Right side axle plate
      XE 6 2
      Left front by sidecar mount
      YE 762E
      • FLFD7
        • Feb 2021
        • 739
        Frame neck
        XE 35
        Front motor mount
        XE 621
        Rear motor mount
        XE 624 2
        • FLFD7
          • Feb 2021
          • 739
          And the forks…
          And the casting number
          TC 20TF 4
          Thanks in advance for any info you can give.
          Joe
          • FLFD7
            • Feb 2021
            • 739
            Wow Jerry, thanks for the quick answer!
            • dukekleman
              • Jul 2022
              • 596
              FLFD7,
              I believe the front fork bracket to be a late 1939-1940.
              Duke Kleman
              • FLFD7
                • Feb 2021
                • 739
                So 40 frame and 40 fork, makes sense….
                • otis71
                  • Jul 2015
                  • 597
                  The TC 20 spring fork is later. Without looking in the book I’d guess early to mid 50s servicar.
                    • 2024
                    Rigid fork is welded so no older than 1943/44. Spring fork is earlier maybe correct for 1940. Jerry
