Is there a way to tell the Reproduction 41-46 Gas Tanks from the original.I bought a set of tanks and they hit the rear off the the dash base.You can not raise the tank enough to get the bolts to line up an the frame.Is Vtwinn the only one making them.Do they have the tank strips on them.
Reproduction Gas Tanks.41-46
I recently mounted a set of tanks and ran into a problem with the rear of the dash base hitting the tanks. The base was aftermarket, the tanks are factory. I had to trim the rear of the base to get everything to fit. Perhaps you have the same problem...
vph-d
DanOriginally posted by vph-d View PostI recently mounted a set of tanks and ran into a problem with the rear of the dash base hitting the tanks. The base was aftermarket, the tanks are factory. I had to trim the rear of the base to get everything to fit. Perhaps you have the same problem...
vph-d
From my experience the rear of the reproduction tank is wider than an OEM one.
Jerry
