Clutch Steel Drive Disc with Anti Rattle Device Stamped "Out"
  • wmarketst
    • Mar 2015
    • 9
    My Question is are Clutch Steel Drive Discs with Anti Rattle Devices actually directional and thus the reason they have one side stamped "Out"
    The reason I ask is I've noticed some reproductions are NOT stamped. So if they are not stamped how would you know which side faces OUT?
    Or does it really matter?
    Thanks clutch challenged
    • 4790
    The "OUT" is for plates with factory anti-rattle springs, they are directional. Plates without springs can go in either way.
    • wmarketst
      • Mar 2015
      • 9
      Understand, but if you have a set of reproduction plates with anti-rattle device that are NOT stamped "Out" is there a way to tell which side would go out?
      I have a set that are not stamped and would like to know i'm installing them correctly.
        • 4790
        They go the direction shown in the Service Manuals...
        https://www.hydra-glide.net/phpBB3/a.../article?k=437
        • wmarketst
          • Mar 2015
          • 9
          Got it
          Thanks for the reply
          • RichO
            • Dec 2001
            • 903
            Hope you have better luck with the repops then I did. Clutch fibers rubbed against them and made the clutch drag. They are not needed so buyer beware. Plus they come apart.
            DrSprocket
            • otis71
              • Jul 2015
              • 597
              The rattle devices go to the clockwise side because the clutch hub spins counter clockwise.
