Speedster Handlebars
  • 47Knuckle47
    • Jan 2021
    • 26
    Can anyone recommend a source for an assembled set of Speedster bars, offset, black?
    Tim
  • jonnyoctane
    • Jan 2018
    • 6
    fabercycle.com
    • RichO
      • Dec 2001
      • 903
      # 305757148247 Flea bay texas free ship complete 46-48 speedster bars chrome
      DrSprocket
        • 4790
        Links are easy..
        https://www.ebay.com/sch/i.html?_fro...48247&_sacat=0
        • 47Knuckle47
          • Jan 2021
          • 26
          Thanks guys. I did nave a message into Tom Faber and have been on his website. Quality stuff. I also noticed those bars on Ebay, which for my purpose I would want to refinish black. Follow up question, I do have a set of bars that would need to be rebuilt if I can't find what I want. How do I get the cables out after removing the the grip assemblies? They seem to be in there pretty tight. The setup that I have is not like what is described in the service manual.
            • 4790
            Have you taken the set screws out of the bars to release the cable spools? Soak them well with Kroil or another good penetrant as the spools are often a tight fit .
            • 47Knuckle47
              • Jan 2021
              • 26
              That would seem to be my problem. I'm assuming the set screws are inside the bars attached to the spools? I'll get a flashlight in there to take a look.
              Tim
                • 4790
                Tim
                No, they go in from the outside of the bars, one under the headlight switch and the other on the underside of the right side of the bars in the same orientation. Small slotted head screws, often covered with paint.
                • 47Knuckle47
                  • Jan 2021
                  • 26
                  Ha! Found them. Had no idea. First time taking a set apart. Thanks Robbie, you have helped me out before in the past. Very much appreciated!
