Timer bracket
  • macca
    • Nov 2020
    • 89
    Timer bracket
    G;day I have a 1946 model .can somebody post a pic or tell me the correct timer bracket & the type of bolts of screws that should hold the regulator to it & it to the crank cases .All my manuals say different thing I know there is early & late brackets So when did they change.
    Thanks Mac
    • 4790
    Thanks Mac
    Brackets changed for the '47 season. The '46 and earlier bracket has a curved slot the vertical post clamped to the timer rides in. The '47 and later timer has a horizontal post that adjust in an internal slot in the timer base and the simple bracket hold a clamp for the timer control wire to attach to. The relay mount screws are round head slotted parkerized 1/4-24 thread as used in several other areas on the bike.
    • macca
      • Nov 2020
      • 89
      Thanks for your reply Rubone so are the hold down screws for the bracket to the case the same as the reg to the bracket?
        • 4790
        Yes, they are with a slight length difference.
