Rear brake pedal pivot stud
  • Rear brake pedal pivot stud
    What is the best way to P1080809.JPG rivet a new stud onto the backing .This one is worn out and has been welded
    Use a good rivet gun. Colony makes the stud and washer.
      Depending on how long it has been loose you may need to repair the hole in the plate as well.
        any idea were i can get a bit for the rivet gun that will make were you peen it look like factory
          try hanson rivets: https://www.hansonrivet.com/
          AMCA #41287
          2020 Heritage Classic 114
          1989 Springer Softail project
          1972 FX Boattail Night Train
          1972 Sportster project
          1971 Sprint SS350 project
