Knucklehead Diving Board Repair
  • Beemererik
    • Oct 2014
    • 95
    I have a head that has the small center diving board that supports the rocker assembly broken off. I am not a welder and am looking for a source to repair this head. Any recommendations on someone with experience with this type of repair?
    Erik Bahl
    1929 BMW R63
    1915 Harley Davidson 11F Twin
  • jgbrown59
    • Jul 2008
    • 83
    One option is Advanced Cycle Machining in Superior, Wisconsin. I've had them fix panhead cylinder fins, sleeve cylinders, repair a kicker cover (plug and kicker bore), & repair a panhead case. They do nice work.
    Good luck!
    • tgarcia
      • Jan 2023
      • 116
      Do you have the broken piece or does a new part have to be made?
      • painterdale
        • Oct 2013
        • 423
        Good luck!
        Agree. They did some work for me. Great job. Very reasonably priced and fast turnaround.
        Dale
        • Beemererik
          • Oct 2014
          • 95
          I don't have the original piece. I bought a repair part from Cimarron Cycle.
          Erik Bahl
          1929 BMW R63
          • tgarcia
            • Jan 2023
            • 116
            That shouldn't be too tough for a good welder,I've fixed a few of those and they are pretty easy. If you have a machine shop near you with a good tig welder they should be able to set you up.
              With all due respect to Cimarron, Erik,...
              A stitched-on piece will never be as strong as building the bracket up bead-by-bead, and then carving and machining the bolt hole square and centered.
              I was successful with bronze filler decades ago, but it would have been better if I had known cast iron piston rings are ideal.
              Most modern welders dogmatically use silicon bronze, which is far more difficult to sculpt.
