Black cloth tape
  • DANPATCH
    • Apr 2009
    • 313
    Black cloth tape
    any body know were to get the right tape . I have ordered a couple of rolls from different paces and they are not even close
    • 4790
    Have you just bought plain old friction tape from the hardware store?
      Nothing like the real thing, Dan!
      • DANPATCH
        • Apr 2009
        • 313
        How wide was the tape .Thanks for the response. I bought the tape of off the internet . It is cloth but it is real thin and not very stickey
          • 2044
          The modern hardware store stuff doesn't stick like the older stuff did.
            • 4790
            I have had good luck with "hockey" tape.
              It says 3/4" on the can, Dan!
              I'd be surprised if my Manson still sticks; Just a vanity shelf item.
              Found decent generic friction tape at a big-box store a few years ago, but I'm about out...
              • PaulCDF
                • Aug 2019
                • 1433
                Try: Home - The Brillman Company | Antique Tractor & Auto Electrical Parts
                3/4" x 60 ft.
                • dukekleman
                  • Jul 2022
                  • 596
                  Cotton, I too have a container like yours of Manson tape.
                  Now days all I use is Coroplast abrasion and heat resistant tape. It's OEM on many harnesses. Tough stuff, you won't tear it like other tapes, it must be cut.
                  Duke
                  • DANPATCH
                    • Apr 2009
                    • 313
                    ordered a couple of role from The Brillman Company | Antique Tractor & Auto Electrical Parts.They listed the tape as .Old Style Cloth Friction Tape
                    $4.50
                    .Thanks for you help
                    • motor-officer
                      • Feb 2011
                      • 199
                      I bought a roll at Home Depot. I believe it is made by 3M. Works great.
                      • Shovelhead68
                        • Jul 2016
                        • 46
                        Shop Dope Nov.16,1937 # 9 . Tape and shellac entire length of gas and oil pipes. This is what I do for wiring using the old tape that won’t stick, also can soak cloth strips in shellac to make your own covering , period correct? not my call.
                        • Iacovos
                          • May 2012
                          • 208
                          And this can be used to tape the wiring looms on the frame correct? As it was done by the factory as well?
                          thanks
                          • PaulCDF
                            • Aug 2019
                            • 1433
                            Not sure if it is 'factory correct' more like period/era correct and works well.
                            I paint a little rubber cement on underside of last wrap to insure things stay together.
