“1936” Knucklehead on EBay
In comparing the 2 pics, you wonder how this was accomplished. I don't seen any machining marks on the boss or the capture lugs for the speedo clip. I wonder what the belly numbers look like? Think this may be a factory replacement case?Originally posted by Jdiesel25 View PostBad vin number
Here is a link showing what numbers should or should not look like, https://vintageamericanmotorcycles.com/v/Numbers/Be sure to visit;
- 1 like
Only the very earliest 36 did not have the tabs for the speedometer clips.Originally posted by dukekleman View PostWas there a Mid-year production change made in the crankcase castings? My reason for asking is that I've seen some 36' EL's that do not have the casting tabs for the anti-rotational speedometer cable clip. Or are those incorrect crankcases re-stamped?
For 1936 Knuckleheads the earliest I’ve seen the two nubs are four cases with SN 12++. But that doesn’t mean all cases with higher SNs had them. Most probably did but some didn’t. For example I have photos of seven with SN 15++ but only six have nubs. And I have photos of four with SN 21++ but only three have nubs.
Eric
Originally posted by Chris Haynes View PostHere is a link showing what numbers should or should not look like, https://vintageamericanmotorcycles.com/v/Numbers/
Once again I see a link to case numbers on VAM and as usual those pages contain some SNs that are not consistent with factory stamping yet they are not described as such. For example 39EL1414, 41FL3553 and 47EL13649. And there are several others as I’ve said over the years on one site or another.
Eric
