police fender??
  • hdhikaru
    • Feb 2010
    • 217
    police fender??
    this oval cut .... is this police fender? how dose this cut work?
    this is on 46FL so this bike might be former police/// :any other way to ID police other than the fender??
    tks Shin
  • RichO
    • Dec 2001
    • 903
    That is for the siren roller that engages the tire. On some Knuckle police bikes I have seen an extra toolbox strap on the left rear legs, a third post on the ignition coil, and the TP fix jet carb (I believe it to be).
    DrSprocket
      • 2024
      That is a cut-out to accommodate the siren as a lot of police bikes had. The dash base might have a little spring arm mounted to the left side to release the speedo lock. Sometimes the carb might be a M75 or M75F.
      Jerry
      • hdhikaru
        • Feb 2010
        • 217
        thank you guys!! one more.. can you tell if its police from this VIN#? IMG_1595.JPG
          • 4790
          No, the VIN doesn't have any build info in it. Merely the sequence when it was built. Without the order info no one knows what it originally was.
