Outer diamond primary
  • DANPATCH
    • Apr 2009
    • 313
    How do you tell the Outer diamond primary original from reproduction .I thought it has something to do with how the diamond was stamped.
    • 4790
    The way the diamond is stamped is one thing, the depth and shape of the sprocket clearance is another. Originals have a pronounced radius where the diamond meets the domes, aftermarket are straight. The front sprocket stamping is a very shallow domed area, aftermarket are taller and more square sided.
    • larry
      • May 2009
      • 247
      Has anyone ever reproduced a cover with the correct dome?
        • 2024
        If someone has I have never seen it. Jerry
          As far as judging on a restored machine goes, if it is the best reproduction available it is fine.
          • EricOlson
            • Jan 2011
            • 578
            Here's a picture showing the area Robbie is talking about. You can see the difference circled in red.
            Eric Olson
            Membership #18488
            • pan620
              • Oct 2016
              • 223
              So what is the best reproduction that is available
