Help identify frame
  • Jdiesel25
    • Mar 2018
    • 295
    Help identify frame
    Left side neck xe-35
    Right side neck #4
    Left side axle plate xe-7 #4
    Right side axle plate xe-6 #2
    Left side car loop ye-761e
    Right side car loop ye-762e
    Front motor mount xe-621 #3
    Rear motor mount xe-624 #2
    paint is pretty thick so from what I can this these are the numbers I could make out. Trying to find out what year the frame is. Will attach picture of frame also
    This gallery has 1 photos.
    • 2024
    I think it is an early 1941 'induced rake" frame.
    • Jdiesel25
      • Mar 2018
      • 295
      Thank you sir. That’s what I came up with but not as knowledgeable as some on here. Thanks again
        • 2024
        The giveaway is the kink in the main backbone tube between the rear tank mount and the neck casting. The toolbox bracket is 41 only too. Jerry
        • Jdiesel25
          • Mar 2018
          • 295
          Ok thanks!
