Need help from a Knucklehead expert
  • Jdiesel25
    • Mar 2018
    • 295
    Please respond here. Looking for someone who can help clarify some frame numbers and give opinion on a vin
    thanks in advance
    Other than forging numbers there are no numbers on a Knucklehead frame. No VIN on a Knucklehead frame. For engine numbers go to http://www.vintageamericanmotorcycles.com/v/Numbers/
      • 4790
      Which frame numbers are you referring to? There are a lot scattered around, and as Chris says they are all forging numbers. Without a picture of the VIN you are on your own.
      • Jdiesel25
        • Mar 2018
        • 295
        I’m aware of that could either 1 of you private message me your email?
        thanks
        • MMasa
          • 1192
          Pretty “cloak and dagger”
          Mark Masa
          www.linkcycles.com
          • Jdiesel25
            • Mar 2018
            • 295
            Right Side Steering Head (Code #8), Left Side Steering Head (Code Xe-35), Right Axle Clip (Code Xe-6 #3), Left Axle Clip (Code Xe-7 #5), Front Motor Mount (Code Xe-621 #4), Rear Motor Mount (Code Xe-624 #2), Floorboard Mounts (Code #760), Right Side Car Loop (Code #ye-761e), Left Side Car Loop (Code #ye-762e), The Seat Post Bracket (Code Xe-1 #3),
            springer #7
              I don't have my "How To Restore Your Harley-Davidson" book with me. All the forging numbers and dates are there. www.howtorestoreyourharley-davidson.com
              • Speeding Big Twin
                • Mar 2010
                • 433
                I'm not an expert on anything but I’ll try to help. If H-D the frame sounds like a 43 model or maybe 42? But you’ll also find forging numbers and die numbers on some AM frames so clear photos of everything would be a good idea. Another marking found on some Harley frames is a repair number and it is usually stamped on top of the seat post forging.
                As for the SN, could you post a partial photo please. F/FL or E/EL? If the former you may find a certain type of 7 on top of the cases near the rear engine mounting bolts. Photo? If the latter there should be nothing there and no sign that anything was removed. Photo? If you find 7s on top of cases stamped E/EL then the E may have originally been F.
                Pictures of both BNs would also help.
                Re the case numbers on VAM, as usual I advise caution when viewing them because some that are not consistent with factory stamping are not described as such. For example 39EL1414 (maybe dealer-stamped?), 41FL3553 and 47EL13649. And there are others.
                Eric
                • Joseph Mangelos
                  • Oct 2019
                  • 47
                  I agree, when someone asks for help then doesn’t want anyone else to hear the answer, I think they are ridiculous. We are here to help each other not to keep secret I might have the same problem. Isn’t that what the forum is for to help each other?
                  • Jdiesel25
                    • Mar 2018
                    • 295
                    Eric
                    Thanks that’s what I was thinking also!
                    • Jdiesel25
                      • Mar 2018
                      • 295
                      No sir that’s not the case. A friend of mine came across this bike so I don’t have a bunch of pics and some people are weird about posting their vins online. It’s not my bike just trying to gather info before possibly purchasing. Sorry if it came off the wrong way.
                      • Joseph Mangelos
                        • Oct 2019
                        • 47
                        Good explanation I agree with you, people are occasionally odd about posting vins and since it’s not yours yet we must be respectful.
                          Here's mine. It is registered in my name. Would somebody be foolish enough to use a number that is already registered? Why the paranoia about showing your numbers? 36el1004_zpsifxumokg.jpg36el1004_zpsifxumokg.jpg
                          • Jdiesel25
                            • Mar 2018
                            • 295
                            Thoughts?
                            This gallery has 1 photos.
                              A 1943. Very rare. Numbers look good. What about the bottom numbers?
                              A 1943 frame has all the joints brazed, not welded.
