Pogo seat
  • Joseph Mangelos
    • Oct 2019
    • 47
    Pogo seat
    My seat springs are too soft and I want to pull that pogo shaft out and put heavier springs in it but how do I get it out? It’s a 47 Knucklehead.
    Thank you
  • Architect
    • Dec 2014
    • 283
    There is a nut under the frame. Look at the parts manual for an exploded view, pretty straight forward. It is in line with the frame tube and pogo.
    Colony makes a great set of heavy Duty springs, fixed my issues with the seat bottoming out. Good luck.
    • HDSmitty
      • Jul 2017
      • 282
      Might want to check for play in the bushing to seat post area also, perfect time to do it and bushing replacement is fairly easy. Hope this helps.............Smitty
      • Joseph Mangelos
        • Oct 2019
        • 47
        Thank you to both you guys, it was as you said a simple repair.
        • Joseph Mangelos
          • Oct 2019
          • 47
          I bought the Colony springs but I must be doing something is wrong, even with the 250 plus setup it bottoms out and I weight 220. I’m going to call Colony in the morning.
          • bobphd
            • May 2008
            • 99
            Did you install the upper spring set per instructions above the rebound spring? I too weigh 220 and have found that with the correct purple and silver upper springs the ride was too firm for me and instead used the white and silver for up to 200 pounds. I have these in several bikes and they work very well.
            Bob
            This gallery has 1 photos.
            • Joseph Mangelos
              • Oct 2019
              • 47
              Bob
              No I didn’t so that’s my problem, thank you for the advice. Here is my Knuckle and my 41 Indian Chief.
              • Joseph Mangelos
                • Oct 2019
                • 47
                • bobphd
                  • May 2008
                  • 99
                  You have to unscrew the the rod 51661-36 from the plunger 51626-36 as the 2 springs 51780-30 and 51778-30 are above the rod inside the plunger. Make sure you also stall the colony rebound spring that replaces 51777-30 .
                  Bob
                  • Joseph Mangelos
                    • Oct 2019
                    • 47
                    Bob
                    Thanks to your advice bobphd it now works perfect.
                    thank you again for taking the time to help me
                    • HDSmitty
                      • Jul 2017
                      • 282
                      and a Cobra for when ya just wanna go a lil faster?
                      • Joseph Mangelos
                        • Oct 2019
                        • 47
                        You are one observant little guy, and yes that’s a 67 Cobra with a 427 side oiler and top loader 4 speed.
