vin and belly#
  • hdhikaru
    • Feb 2010
    • 217
    vin and belly#
    hi there,
    this is from a bike on ebay now. belly# should start 42- as the vin# is 42xxxx....
    is this restamped? or common factry matter?
    • 2024
    I think this case is original. It is not uncommon to find previous year belly # on low VIN # cases. Jerry
    • hdhikaru
      • Feb 2010
      • 217
      thanks Jerry,
      any opinion about the 42 on ebay?
      • kitabel
        • Sep 2018
        • 471
        Horrible re-stamp
        The Linkert Book
          • 2024
          Not a re-stamp - all late 41 to 43 cases have the streaks in the vin. jerry
          Originally posted by kitabel View Post
          Horrible re-stamp
          • 1950Panhead
            • Jun 2010
            • 343
            42EL1534 is factory stamped.
            Bikes built in early September use cases line bored and stamped in August.
              • 4790
              Perfect '42 numbers. All known originals look just like that.
              • KNUCK
                • 827
                Numbers look good to me, and I seen a few.
                • kitabel
                  • Sep 2018
                  • 471
                  You mean the grinding marks, where the pad thickness is reduced? LOL
                  The Linkert Book
                  • Speeding Big Twin
                    • Mar 2010
                    • 433
                    I see no re-stamp, 'horrible' or otherwise. What I see on the SN boss are sometimes called striations and they are common with Knucks for 42 and some other years. They aren’t always there but they appear often enough and it’s something that has been mentioned many times on forums. In fact this bike in particular was discussed on CAI in September 2016.
                    Sometimes the striations are more pronounced than on this bike and sometimes less. At times you’ll find them more through the middle of the boss and/or along the bottom edge.
                    On occasion you’ll find what looks like a recess below the decade 4 and I’ve seen close-ups of it on a few engines.
                    I can't see anything wrong with the SN characters and they all appear consistent with factory types for a 42 Knuckle.
                    Re the BN, it’s the second highest 41 I’ve seen for a Knuckle. It’s not uncommon to find previous year BNs on cases with a low SN from the next year, as mentioned above. I can’t see anything wrong with the BN characters and they all appear consistent with factory types for 41.
                    Eric
                    • hdhikaru
                      • Feb 2010
                      • 217
                      thank you all for good information!!
                        • 2024
                        Here is my 1942 FL vin. Jerry
