Question about 47 Knuckle tool box mount
  • oldblu
    • Dec 2018
    • 17
    Hi, new to the forum but not to old bikes. Restoring a late 1947 non-bull neck straight leg Knuckle and I am attempting to use the correct tool box mounting bracket 47386-41 does it take the three hole bracket or two hole is it mounted with bolts or welded i have seen it various ways? I would prefer someone who has and original late 47 to explain. Thanks much oldblu.
  • 1950Panhead
    • Jun 2010
    • 343
    Vertical bracket welded to frame.
    Horizontal bracket mount high with three parkerized screws, police bikes differ.
    • 55tmm
      • Dec 2009
      • 158
      I have an original '47 with Loctite bags and the toolbox mounted low, I was told with bags, toolbox mounted low is correct ?
      • 1950Panhead
        • Jun 2010
        • 343
        40 to 47 toolbox was mounted high with factory bags, factory photo 860, 869, 871, police bikes differ.
        • oldblu
          • Dec 2018
          • 17
          55tmm: thanks for the very informative information, i will be putting loctite bags on mine as well, does yours have a two hole or three hole horizontal bracket and is it welded on or bolted on and hoping you have a late xe-12 frame. this would be most helpful. Thanks again oldblu.
