Can someone help identify this Cam Cover? (its heavy)
  • knuckgush
    • Oct 2008
    • 16
    Hi,
    Could anyone help me identify this cam cover? I think it's from a Knuck, even though it came off a Pan/Shovel.
    It weighs a lot more than most other cam/timing covers i've handled.
    Thanks in advance!
    • 2024
    That sand casting was used in early 1940 and then again in the early 1950's. Mid 1940 it was replaced by the Alcoa built permanent mold cover which was used into the early 1950's when this HD built cover reappeared minus the overhead oil hole. That being said the casting date on the 2nd photo suggests that this was originally an early 50's cover which someone has drilled for knucklehead overhead oiling.
    Jerry
    • knuckgush
      • Oct 2008
      • 16
      Thanks Jerry!
      Another thing, can you explain the casting date?
      • 1950Panhead
        • Jun 2010
        • 343
        Cast in December 1950 for 1951 pan, someone modified for knuckle engine
        • knuckgush
          • Oct 2008
          • 16
          So the 120 number inside the casting means December of 1950?
          (12 = Dec. and 0 = 1950).
