delco horn restoration
  • dcmc
    • Oct 2015
    • 18
    Have a Delco Remy 16 horn, that needs a new rear strap. Anyone have experience replacing the staked on rear mounting strap? I need to know how best to remove it, and how to re stake it. Have found replacement strap but not that center post.
    Thank You
    I have heard that a guy called Mutt is the Delco horn man to go to.
      • 4790
      Mutt is Charles Hallam in Texas. His contact info is on the Harley Hummer Club site.
      • dcmc
        • Oct 2015
        • 18
        Thanks Chris,
        Would like to just do it myself, maybe chuck it up and turn off a few thou from stud, etc. Want to hear from someone with some knowledge of the horn assembly.
        • 1950Panhead
          • Jun 2010
          • 343
          I have replaced many, drill through center to release washer and bracket, post is not available, I made several.
          • dcmc
            • Oct 2015
            • 18
            Thanks 50 panhead,
            exactly what i was looking for, Is the post loose in there once you drill from rear ?
            • 1950Panhead
              • Jun 2010
              • 343
              Thanks 50 panhead,
              The coil is wound on a paper washer, once I was lucky and pulled the coil off the pin, all the other times I had to rewind the coil on a new paper washer, there are two paper washers on the side.
