Bob,
I assume that the OEM bracket is shown in the photo? The bracket that I have from Ted looks nothing like that. I can see that tweaking the OEM bracket shown would be quite easy. Tweaking the VTwin bracket that I have simply won't work as its way too short. Might you know the whereabouts of another OEM bracket?
Also, I can see how close your filter is to the air cleaner and how the housing is turned counterclockwise (looking from the top) to allow a better alignment of the inlet oil line. Good information...
Finally, is the inlet fitting to the filter drilled straight in (vertically) or is it angled slightly toward the oil pump? Mine is angled and I don't know if that's original or if someone messed the thread up at some point.
Thanks!
Thanks!
Originally posted by bobphd
View Post
