Knucklehead cam cover?
    • 2024
    Anybody know anything about this HD cam cover? Front side looks like 1940 and up Alcoa cover but every Alcoa cover I have ever seen has the tin baffle while this one has a cast in baffle like the 1940 and down OEM sand cast ones. Is it a Repop?
    http://www.ebay.com/itm/112009653051...%3AMEBIDX%3AIT
    • 4790
    Looks repop to me, the surface coarseness is odd too.
    • billpedalino
      • Mar 2005
      • 1096
      That could be a 1951/1952 cover with the rear boss drilled for the earlier knuckle overhead oil line. Surface could have been previously blasted with a course blast media like black beauty or course sand. But...... it does have the later (1954-up) pinion bushing. I'd go with Robbie's opinion - most likely aftermarket.
      Bill Pedalino
      Huntington, New York
      AMCA 6755
        • 2024
        Except that it is missing the little boss on the top front that the 51 cover has. I am sure it is repop.
        • acemoto
          • Sep 2011
          • 121
          What does a 1940 Knucklehead cam cover look like , I need one any one have one for sale or trade
          email acemoto@me.com or call or text 917-541-8400
            • 2024
            It basically is a 1939 sand cast cover that they added fins to the pattern. It is the same as 1951 Pan except it is drilled for overhead oiling. A lot of the 1940 covers advertised on eBay are actually 1951 covers that were drilled and tapped. You can tell by the date code. I could post a picture on Monday if someone else does not. Jerry
            • RichO
              • Dec 2001
              • 903
              There was a change some were in the 1940 EL models and the later ones have the 1941 to 1947 Knuckle style die cast covers.
              DrSprocket
                • 2024
                This is a 1950/51 but it is the same casting as 1940 except not drille for overhead oiling. Jerry
                https://www.ebay.com/itm/142846065113?ul_noapp=true
                  • 6034
                  51g copy.jpgPerhaps someone could explain that casting feature that is on the sandcast cover.
                    • 2024
                    That is on all 1936 to mid 1940 covers and I have heard anything from provision for tach to sand discharge hole. I do not really know. Jerry
                    [ATTACH=CONFIG]22351[/ATTACH]Perhaps someone could explain that casting feature that is on the sandcast cover.
                      • 2024
                      Then there is this picture of a 1938 cover sent to me by Steve Little. Jerry
