Paint for knucklehead exhaust
  • knuckjunky
    • Nov 2009
    • 76
    Does anyone have a suggestion on black heat paint for the exhaust on a knucklehead? Wondering if there are any types that is generally used.
    Eric Hitzel
    AMCA 14954
  • sirhrmechanic
    Vigilis
    • Dec 2010
    • 1147
    I've started using Black Velvet from the makers of POR-15. It's outstanding.
    I despise POR-15. But all the things that make that 'paint' worthless for restoration, seem to make their exhaust paint excellent.
    It's not cheap. But one little can will do 2 exhausts. It will smoke, smell a bit on first startup. Then bake on nicely.
    There are other alternatives... BBQ aerosol paint works fine. From hardware store. Flat black/grey and looks right. And there are some heat paints you can get for blocks/engines, etc. But the Black Velvet seems to be the best I've found.
    Cheers,
    Sirhr
    • wideglide38
      • Jul 2008
      • 656
      I've used Bill Hirsch's Space Age Black, a 1600 Deg. black, with good results. The color appears to hold after heating. The Black Velvet reads like a great solution to painting exhaust systems!
      Depending on the color, our exhaust coating spray can withstand temperatures from 1600°F to 2000°F. Add this high temp exhaust manifold paint to your stock.
      William
      William Edwards, AMCA #10035
      • Highlander
        • Feb 2006
        • 97
        I've used the paint for barbeque grills, in both silver and flat black, with great results and you can get it most anywhere.
          • 6034
          I would use barbeque black from Walmart because it's probably cheaper than anywhere else. A knuck is going to spew a lot of goo, and then cooking it onto the header pipes, so you'll be touching it up many times. It's been many years since I've owned a knuck, but I remember the headers always looked bad.
