frame (re) work
  • FNG1
    • Oct 2014
    • 202
    frame (re) work
    I just wanted to share some pics. I used a mill, lathe, 110v mig welder, die grinder, file, small needle scaler, and a coarse wire wheel.
    • 1676
    Impressive work, nice save!
      Very nice work! I really like the scroll on the axle carriers. Imagine going down and that thing catching you in the kidneys. Guest they went along with the Dave Man poster "Ride Hard, Die Fast" Yuk. Bob L
        • 6034
        Beautiful work. The sidecar lugs look perfect.
        • FNG1
          • Oct 2014
          • 202
          Thanks, not bad for an amature. I didn't want to hurt my arm patting myself on the back but I was really happy with the way this turned out. There is still a lot that you can do for yourself if you take some time. And if you dont like how it came out, just grind it off and redo it.
          • knuckleheadtim
            • Jan 2008
            • 141
            Very nice work! It just goes to show, with some imagination and a lot of elbow grease, you can still build a presentable ride without spending a large fortune.
            • MJW
              • Mar 2007
              • 127
              Nice job new guy! Did you make a tracing of an unmodified axle plate to go by?...Mike
                Did you use the V-Twin replacement parts? I have used their sidecar lugs with great success.
                • FNG1
                  • Oct 2014
                  • 202
                  For the sidecar loops I turned my own. I cut a 5 degree draft each side of center and left enough stock to work in a parting line. It doesn't run on an angle like a real one but I think it still looks good. I got the dimensions from an early shovel frame. There was enough of the hole left on my frame to locate them. I used an old print of a panhead frame for the axle plates. There were no dimensions so I just scaled the best I could and went with that. You could use an original frame to make a template. The template ( piece of sheet metal ) is located using the 9/16" holes. I turned down 5/8" bolts to pin it to the frame. Then the pieces are bolted to it for welding. It works for both sides and turned upside down it locates the chain gaurd tab. Thanks for all the interest
                  • FNG1
                    • Oct 2014
                    • 202
                    Oops, I meant the exhaust mounting tab.
                    • Snakeoil
                      • Jan 2008
                      • 219
                      Yes, very nice. I believe that doing this sort of stuff on your own is very rewarding.
                      Regards,
                      Rob Sigond
                      AMCA # 1811
