Earlobe restoration
  • Steve Little
    • Apr 2008
    • 915
    Earlobe restoration
    I was talking to a mate on the phone the other day and he said he is getting ready to build a another knuckle engine.
    He said he had bought some pieces on eBay that had some light wear and tear, and could I have a look at them and fix any anomalies.
    Personally I think he’s annoyed that I’m retired and just buys this junk to keep me doing something.
    People have said that working on Harleys is like tractor technology.
    I think the previous owner may have heard that term to.
    When my grandmother had a mood going on, she would grab my ear lobe and rattle my eyeballs to make a point.
    The following message could have been delivered the same way to the previous owner, just before he messed it up....There is no place to work on a Harley with a 40oz hammer!!! ….using the earlobe, eyeball rattlin, method to best effect.
    Steve Little
    Upper Yarra Valley. Victoria.
    Australia.
    AMCA member 1950
  • hairynob24
    • Feb 2011
    • 347
    Steve , i through all knuckle heads looked like that , its not for St-uts is it....Rob ps G,day
    • Steve Little
      • Apr 2008
      • 915
      G'day Rob. Nope, this isnt part of Shanes horde.
      Did some weld prep on the crack and popped it in the oven to pre heat 300F -150C before welding
      Welded the crack first and then pad welded the dented area.
      Steve Little
      Australia.
      AMCA member 1950
      • Steve Little
        • Apr 2008
        • 915
        Used the original machined surface that the rocker nut snugs up to and made a little machine stool so that I could pull it down tight to the table.
        I used a angle face plate to give extra support to the bottom machined surface, (where the rocker box mates to the head).
        Then did a few light cuts to bring back to the original height.
        Steve Little
        Australia.
        AMCA member 1950
        • Steve Little
          • Apr 2008
          • 915
          The next step was to clean up the bore for the rocker arm seal.
          I should mention at this point, that I am not a machinist, and my only experience has been under the guidance of the 2 toolroom machinists who used to work for me when I had the frame business. Most of that tuition consisted of them yelling at me, (whimper, sniffle, sob) when I left the key in the lathe chuck,.
          I centred the machine over the bore by clocking onto the 3 original sides with a dial indicator.
          Taking 015” cuts, I bored it to within a few thou” of the finish cut.
          Using a red texta pen, I coloured a small section of the original surface and adjusted the tip of the cutter until it made light contact with the colour on the surface.
          Then said a quick prayer, flicked the switch and crossed my fingers just for extra insurance.
          Steve Little
          Australia.
          AMCA member 1950
          • Steve Little
            • Apr 2008
            • 915
            Well, against all odds it came out very nice. The cutting tip didn’t take any of the original bore, but wiped the corrosion dust off the wall and cleaned up the welded side.
            I clocked onto the other bore and checked it for roundness, as it had a small hammer mark on the top side as well.
            I wanted to be sure that the seals were not distorted by the hammer dents.
            I have been told that the aftermarket rocker seals are a lot tighter on the shafts than original seals when new, and can hold a rocker so tight that it will hold a valve open.
            A dent into the bore would only make that situation worse.
            So in with the boring bar just to make sure.
            It only took a few thou off an area about /18” long, which was directly under the hammer mark and wiped the white mange corrosion out of the rest of the bore.
            At least I know it’s been checked.
            Steve Little
            Australia.
            AMCA member 1950
            • Steve Little
              • Apr 2008
              • 915
              I tried using Photobucket to get away from thumb nail photos, but could not work out how to get them to the AMCA picture file.
              I clicked the (Internet source) in the AMCA box but got lost from there. Can anyone shed some tips on the easy way to do this?
              Steve Little
              Australia.
              AMCA member 1950
                • 1672
                I'd say Bruce owes you big time! Nice reclamation project.
                When you put a photo in Photobucket you'll see a few options on the right of the screen with your photo. If you move your cursor to "Direct" it will copy the link for the photo. Then, on the AMCA posting page you select the little icon that looks like a painting, that will bring up a small window with two tabs on the top, choose the "From URL" tab, then paste the link from Photobucket into the blank field there. Also, uncheck the box below labeled "retrieve remote file and reference locally" and then your picture will show up in your posting. You pretty much have to have two browser windows active, one for AMCA and one for Photobucket so that you can switch between the two.
                • Steve Little
                  • Apr 2008
                  • 915
                  Thanks Harry. You made it easy.
                  After a little die grinder work with a alloy dremel it came up pretty nice. He can hand polish it from here. The other rocker box just has the mounting lug broken of so it will be a bit boring to see that repair.
                  When I was unwell for long periods I would use the AMCA forum as my daily fix of entertainment...plus a few blogs.
                  Most days it was a bit disapointing. As we all know, nothing much happenes on here. But that could change if a few more people took the effort.
                  I dont watch much telly and much prefere to see pictures of someone doing something in thier workshop or shed.
                  Watching the eveil twin cannonball bike was fun and even though he didnt get it done in time for the race, I would like to thank him for the entertainment and effort of taking the pictures. Even watching him reroof his house was good.
                  Steve Little
                  Australia.
                  AMCA member 1950
                    • 2032
                    Nice work Steve thanx for posting-hope you stay well
                      • 1672
                      Steve, just a little visual aid here!
                      • Steve Little
                        • Apr 2008
                        • 915
                        Thanks Duffy. I have to admit that I enjoy bringing a part back into service with minimum impact on the original look.
                        Thanks for the visual Harry. Dont know how you did it, but I'm impressed. I will keep trying to master the upload, as the thumbnails are a bit restrictive when viewing a picture.
                        Ive taken pictures of the other rocker box fix. Maybe I'll experiment with them.
                        Steve Little
                        Australia.
                        AMCA member 1950
                        • Steve Little
                          • Apr 2008
                          • 915
                          Testing, testing, one two! one two!
                          Bugger!! I can see in the preview that this picture will be a thumbnail.
                          When I get to the AMCA I click GO Advanced, then Add Files, then Basic Uploader, Click on Upload files from Website, Then paste the Photo bucket link. Press Upload.
                          Then my only options are to Insert line or Done.
                          I am not seeing a Retrieve remote file and reference localy.
                          Only thing I can think of is that I may be clicking a different path.
                          Any clues??
                          Steve Little
                          Australia.
                          AMCA member 1950
                            • 1672
                            Originally posted by Steve Little View Post
                            Any clues??
                            Steve, this is sort of a selfish pursuit of mine since I prefer to see the photos in the posting and not have to log into the AMCA site... so here's a couple more visual aids! (full disclosure... I'm on this dang computer most of the day, and I've got customers in 7 time zones...)
                            First step is to select the correct icon to add a photo to your posting:
                            Here's where it takes you:
                            You get there, and then you go back to the Photobucket page and select the "Direct" link so that you can go back to the AMCA page and paste it into the line there. AND... don't forget to uncheck the box saying "retrieve remote files...etc."
                              • 1672
                              And... you pretty much have to have your browser open on two pages, or tabs, so that you can go back and forth between the two:
