1947 el knuclehead
  • DONZIE
    • Sep 2013
    • 9
    1947 el knuclehead
    So from what I've read here the correct springer for a 47 knucklehead would be an offset correct?
    • 4790
    Yes, that is correct. And technically a first generation offset with no hole in the stem for a steering lock.
    • DONZIE
      • Sep 2013
      • 9
      Thanks a bunch Rubone....Any idea what is the best way or where to find one
      • 36 knuck man
        • Dec 2009
        • 294
        Ebay and AMCA meets, thanks, Larry
        • DONZIE
          • Sep 2013
          • 9
          Anybody heard of a process where an inline springer being converted to an offsett. I was told a company specializing in frame restoration offered this modification. Thanks for any help in advance
            • 2024
            You can always tell a front end that has this modification done to it because the profile of the center bridge is different on an offset front end. Find one or run a repop until you do.
            Jerry
            • TimR
              • Sep 2009
              • 74
              Jerry
              Jerry & Donzie here is a visual of the center bridge profile of an offset rigid leg.
              • Panuckle
                • Aug 2009
                • 35
                Why bother trying to make an inline into something it is not ?It still will not pass the scrutiny of some judges.If it's the handling your concerned about the difference is minimal. Sell your inline and buy a47 or 48 springer.BTW you could post a wanted to trade ad on this board and others! Someone may have the offset and need your inline. JMO John
                • DONZIE
                  • Sep 2013
                  • 9
                  From what you guys are saying I'm not gonna go the modification...I'm looking for a real nice offset & am willing to pay...I have a request in the wanted section...one will turn up ...thanks guys
                  • knuckleheadtim
                    • Jan 2008
                    • 141
                    Two reasons not to convert:
                    The lower tree on an offset is also offset 1/8" in the opposite direction, an inline is not. This doubles the effective derake angle.
                    If you offset an inline, the bottom plate is no longer perpendicular to the stem and you will break the steering damper over time by flexing it on turns.
                      But is you find one with the hole no one will ever see it.
