Does anyone know if the Air Intake Shafts, 27216-46 ('46-'48) or 27217-48 ('49-'53) can be replaced with shafts from another model Linkert? Also, does anyone on this site have any of the parts for this choke control available (see page 45 of the '41-'54 Spare Parts Manual) or know of a source. I have the 29455-46 bracket and 27250-46 lever. Thanks in advance for any assistance or advice.
Dash-Mounted Linkert Choke Control
Lonnie Campbell #9908
South Cackalackey, U.S. of A.
Visit the website for vendor and visitor information at www.amcasouthernnationalmeet.comTags: None
Just back last night and saw your reply, I've sent a PM. I want to install it on Barney, my 1950 pan. The tanks were widened I'd guess in 1954 and the choke lever is a PIA to reach. Thanks.Last edited by Lonnie; 01-07-2013, 05:59 AM.Lonnie Campbell #9908
Lonnie,
Is this the choke control your gathering parts for? If so I think Diesel55's parts are for a "Catseye" style dash.
Tim
Its all the same kit, no matter which style dash you are trying to use it on. The complete kit comes with all the parts to mount it to either style dash and there is a template to drill the 46 and earlier style dash to use this kit with it.
Lonnie!
Have you tried a common -33 sidevalve shaft yet?
The only difference that I can imagine would be the indexing of the lever's set screw.
Beware that modern reproductions of the -33 shaft are often drilled wrong anyway!
....CottenAMCA #776
I have not but will see if I have one. Thanks.Lonnie Campbell #9908
