Brake lever dilemma
  • jorrow
    • Feb 2008
    • 347
    Brake lever dilemma
    Ok, I have this brake lever that the brake cable end will not fit into or even come close to fitting into. As you can see by the photos, the opening is smaller than the cable bushing end slit. So, what does this lever belong to? Jeff
    • 4790
    What year are you working on? The early cables (springer brake, 125, etc) are much smaller than Hydra-Glide. There are at least three different slot sizes.
    Robbie
    • Matt McManus
      • Dec 2007
      • 142
      Just feed the cable through the round hole and out the slit and pull on the cable. Then everything will be lined up how you need it to be then.
      • jorrow
        • Feb 2008
        • 347
        Thanks guys, I wasnt aware of the smaller slit opening for springers, but I knew better than to just alter it.You learn something everyday. I will have to grind the cable end a bit shorter to fit but I'll leave the lever intact. jeff
        • jorrow
          • Feb 2008
          • 347
          So, just out of curiosity then, does anyone know which slot sizes go to which years?
          • oldsouthmcy
            • Jan 2009
            • 51
            1941-late 1948, narrow. late-1948 through 1964, wide. Early uses cable bushing 4152-41 to hold the cable in the handle. Late uses cable bushing 4152-49.
            There is also an in-between handle that has a medium slot. Made by B & H for their hand clutch.
            Bruce Palmer III
            AMCA #667
            How to Restore Your Harley-Davidson
            How to Restore Your Military Harley-Davidson
            • jorrow
              • Feb 2008
              • 347
              Excellent, thank you. jeff
              • BigLakeBob
                • 2768
                What years offered the plastic or rubber coating added to the handle, I assume it is from the factory? Thank you.
                Bob Rice #6738
                  Originally posted by BigLakeBob View Post
                  [ATTACH=CONFIG]7758[/ATTACH]What years offered the plastic or rubber coating added to the handle, I assume it is from the factory? Thank you.
                  You assume incorrectly. It is aftermarket.
                  • BigLakeBob
                    • 2768
                    Would it be considered a 'period accessory'? Does anyone know what years these were offered? Thanks again. Bob#6738
                    Bob Rice #6738
                      When Kevin was Chief Judge his ruling was that an accessory was something that was added to a machine. Not something that replaced a part of a machine. I don't know how it is being considered today.
