>>JD Identification<<
  • JoJo357
    • Feb 2016
    • 3296
    >>JD Identification<<
    Greeting's. I need to get this frame year identified. Thank You for your efforts.
    *M.A.D.*
  • JoJo357
    • Feb 2016
    • 3296
    *M.A.D.*
      • 2037
      Not my era but it has the gusset under the neck that came out about 1920 so '20-'24. There may be numbers stamped on the tank mount plate on top of the top tube in front of the seat casting. Many are too rusty to read
        • 6029
        As Roger said, it has the reinforced neck which puts it in the last generation frame type before the Streamlined J's. As Roger also said, look for that number near the seat lug if it is still legible.
        • JoJo357
          • Feb 2016
          • 3296
          Thanks Duffey & Eric. I managed to wire brush the seat lug area serial number pad. The numbers are...2316 113
          *M.A.D.*
          • MMasa
            • 1192
            In the range of 1920 to mid 1923.
            post a side view of the top rear motor mount and I can narrow it down further.
            Mark
            Mark Masa
            www.linkcycles.com
            • MikeW
              • Apr 2015
              • 149
              Hello JoJo
              Some years ago Mark Masa identified a similar frame for me which was missing the plate with the stamped date and number. As I recall, the key indicators were: (1) the reinforced neck (1920-on); (2) the oval shape of the holes in the rear top engine mounts (1921-on);
              (3) the shape of the join of the seat forging to the rear frame members - a visible "step" rather than a smooth transition (1923-on);
              and (4), the muffler brackets; 1915-on and not the different brackets for the 1924 box muffler.
              P1030590.JPG All these meant it was a 1923 frame. It may be that some of these changes were made mid-years but, generally, have I got this right Mark?
              Mike
              • JoJo357
                • Feb 2016
                • 3296
                Thank You Mark Masa & Mike W.. Hope these shots reveal the exact year.
                *M.A.D.*
                  • 2037
                  JoJo, Mark asked for a pic of the top rear motor mount like Mike's 1st pic with oval holes...not the trans mount
                  • JoJo357
                    • Feb 2016
                    • 3296
                    So Sorry, the pleasures of getting old~haha. Thanks Duffey.
                    *M.A.D.*
                      If that frame number is 23F6113 or 23J6113 then job done.
                      • MMasa
                        • 1192
                        Your frame is mid 1922 - mid 1923
                        Mark
                        Mark Masa
                        www.linkcycles.com
                        • JoJo357
                          • Feb 2016
                          • 3296
                          Kindly Thank You to all involved. That #1. i initially listed on the serial numbers, was an F. So it's 23F6 113~instead of 2316 113.
                          *M.A.D.*
                          • MikeW
                            • Apr 2015
                            • 149
                            Were any frame numbers of this era stamped with a "J"? Years ago I was told with great confidence by someone who claimed expertise (very rash) that V-twin frames of this era were all stamped with an "F" - as in 2XFXXXX - even if the machine was an electrically equipped J or JD. Was there any evidence for that assertion?
