Cylinder primer threads
  • MikeW
    • Apr 2015
    • 149
    I'm in the process of assembling my 21F motor. One of the brass cylinder primers screws into its cylinder OK. The other doesn't. The threads in that cylinder are a little rough and, unless refreshed, are likely to chew up the softer brass of the (original) primer. I can't identify the primer threads. It looks like 28TPI with an outside diameter of 13/32" but tapering by about 1/64" top to bottom. I fear that this will turn out to be an oddball thread with no readily available tap - but hope remains.
    Can someone identify the thread size for me and then I can start hunting for a suitable tap.
    (And yes; I know I should have sorted this out before the cylinders were bored and plated and I was well into motor assembly )
    Dear Mike, the thread is 1/8 NPT, a tapered pipe thread. I have a tap here if you can't find one.
      • 2037
      27 TPI for 1/8 pipe
      • MikeW
        • Apr 2015
        • 149
        Thank you Guys. Exactly the information I was after. What a resource this forum can be for those of us on the far side of the world. And thank you for the offer Steve. I've tracked one down here. Mike
