Replacing rod races
  • Stein.S
    • Sep 2021
    • 57
    Replacing rod races
    Hi.
    I am about to replace the rod races at a 1920 model 61´ engine. The new rod races I got does not have the opening for oil to flow into the bearings. Should the new ones be grinded to be like the old races?
    Also, instruction following the new races says to hone the rods before pressing in the races, and to hone the races after installing them. Is the reason for this to clean the surfaces or is it for adjusting tolerances for pressfit and clearance of bearing?
    Regards, Stein-S
    This gallery has 1 photos.
  • aumick10
    • Nov 2018
    • 465
    I ground some oil holes in the new races after i pressed them in and before i honed the races. Don't know how to hone them before fitting, very hard to hold,
    • Stein.S
      • Sep 2021
      • 57
      Thank you for answering my question.
      Regards, Stein-S
        • 8239
        Originally posted by Stein.S View Post
        ....Also, instruction following the new races says to hone the rods before pressing in the races, and to hone the races after installing them. Is the reason for this to clean the surfaces or is it for adjusting tolerances for pressfit and clearance of bearing?...
        Have you measured the interference, Stein?
        Rod bores can stretch out of round, and if the races are oversized, this can be corrected before installation.
        • Stein.S
          • Sep 2021
          • 57
          Hi. Thanks for answering. I have not pressed out the old races yet, so do not know if rods are out of round. But will measure that. Good idea.
          Regards, Stein-S
