Carburetor options 1919
  • Stein.S
    • Sep 2021
    • 57
    Hi.
    My Schebler Hx-160 is in real bad condition. I am concidering buying a Linkert M-18. For me it is not a option to mount a modern carburetor, but if the carb is a carb that belongs to the era where the bike was used, I think its ok. What I want is a carb that works good. That I can trust when starting the engine cold, half warm and warm…..a carb that works well when adjusted. Never had the engine running with the Schebler, but after what I have been told the Linkert M-18 is supposed to be a much better carb…..?
    Do any of you have any experience with this? Will the M-18 fit directly into the bolt pattern of the 1" manifoil? Info I found tell me it will?
    I see there is replicas of M-88 for sale. Will they work with a home made adaptor? Give more power?
    Any other ideas for carb when originality is not very important?
    See there is a lot of carbs for snowblowers that have the "right look". Will they work? Did anyone try?
    attatching a photo of a 25´ I have been working on and driving during the last year. Its not mine. There someone back in the days mounted a Bing 24mm carb. Nice job. Works perfect. Starts at first kick. No problems at all. I am considering this solution, but would be nice if the look was a little more like the original carb…
    Fun thing: The 25´ had been stored since the 60ˋs. Found out when getting it running again that the gas handlebar worked in opposite direction. Owner, now 79 years old could not even remember that it was an issue…..he was in his early 20ˋs when driving it, and in that age you easy reprogram your brain for adapting to everything….. My test drive with that solution was like hell….. Made a new handlebar with opposite slide to not kill myself when driving it
    Best regards
    Stein-S
    This gallery has 3 photos.
    • 8239
    Any 1" Model M or 1" DLX should bolt right up, Stein-S,...
    But you will still need to get it in order as well; Linkerts are certainly easier to refurbish.
    The reproductions currently on the market are 1¼" Models, and have their own issues.
    "Right look" is entirely in your own eye!
    PS: Literature suggests the DLX12 might even be "correct":
      • 2037
      M-16 or M-18 are 1" but your point about same era is incorrect.Those are 1930s & later carbs.Many Cannonball riders use them because they work well.
      • Stein.S
        • Sep 2021
        • 57
        Hi. Thank you for reply. By same era I mean the periode of time this bikes was used. Like the 25´ in the pictures has a carb somebody fitted when the bike was still in regular use. That Bing carb was used on BMW R4 which were a bike from the late 30ˋs. So a carb that looks to be from 40´s and 50´s I think is ok on the 19ˋ model. A Mikuni is not an option…. Sent a message to a seller of a M18. Seems like an ok choice then
          • 6029
          This is what I did, and the parts I made to make a Linkert clear the crazy overhead linkage on my 1916J.
            • 6029
            I forgot to thank BigLakeBob for giving me the Linkert
              • 8239
              Did you reverse the bowl for clearance, too, Eric?
              • Stein.S
                • Sep 2021
                • 57
                Nice to get an idea about how to mount the carburetor. Thanx. Bougt a M18 from ebay yesterday.
                  • 6029
                  I didn't do that, Tom. I'll look at that when I get back into that 'project'; thanks for the tip. It's been sitting due to low compression and who knows how evil that will get.
                    • 8239
                    Hope your gasline reaches, Eric!
                    And hope assembly didn't damage the float (It happens.)
                    The whole point of the offset was to miss the bowlstem...
                    • Stein.S
                      • Sep 2021
                      • 57
                      Thanx for photos and explanation about the float and the offset. Was dealing with mounting the M18 yesterday. Would never think about it as a problem turning the bowl around. Now the float position is changed, and the float moves free with bowl in almost opposite direction.
