JD 1926 Timer
  • Erik Birch
    • Jul 2013
    • 3
    JD 1926 Timer
    Hi
    Can anyone explain me what happens if there are a worm gear 1648-26 (1 cylinder) fitted, instead of the correct worm gear 1648-18 (2 cylinder) on the generator shaft
    The timer is fitted with the correct timer shaft gear.
    Will it work or shall the generator be dismantled,and fitted with the correct worm gear
    regards Erik
  • MMasa
    • 1192
    You need to replace the worm gear on the armature. Firstly, the two gears will not mesh properly and both will be quickly destroyed. Also, the timing will be off and the engine will not run. PM me. I have extra JD worm gears available.
    Mark Masa
    Mark Masa
    www.linkcycles.com
    • Erik Birch
      • Jul 2013
      • 3
      Hi
      Thanks for your reply.
      .It was more or less ,what I have been afraid of.. I have tryed to start the motor ,but without succes. I am sure that the timing was correct, when I finished the assembling of the motor.
      Are there any trial I can do, to be sure that it is a wrong worm gear on the generator ,before I dismantel the motor and generator??? I found 2 different worm gear in my shelfs,which one is correct for the JD26 .Regards Erik
