1917 Tank Lettering
  • jdonaldson
    • May 2012
    • 29
    1917 Tank Lettering
    Need help determining the appropriate tank lettering style for my 1917. Below are 2 screenshots of an original 1916 which show different styles for the left an right sides. Is this correct for 1917?
    This gallery has 2 photos.
    • 6029
    My parts books show two P.N.s for 1908-1932. P.N. 5917-08 red center, and P.N. 5917-08A gold center. I'm not aware of any difference in standard production decals in size, other colors, or fonts. There were racing, and promotional decals that were larger, and different in font, and style. I have also read that there were aftermarket decals, but I don't believe I have ever seen period decals on an old repaint. Genuine H-D decals from the era you have inquired about are very rare, and close to impossible to apply. They were not a water slide decal as we know today. They were applied to a 'sized' surface similar to the way gold leaf is applied. In regards to the 2 pictures you posted, I don't see any difference other than the condition of the tanks.
      • 6029
      I should have said, current aftermarket decals look correct in color, and size, but they are thicker than the 'decals' H-D used; so, if you clear coat a modern decal, it will have that minuscule 3-D effect of being higher than the field under it. Harley coated the decals with a copal varnish to seal the edges from abrasion, and humidity. Otherwise, their decals didn't look higher than the surface they were on top of. We will never see that quality of printing, and decal making again as that seems to be another art that was lost to progress.
      • jdonaldson
        • May 2012
        • 29
        I guess I should have been clearer about the differences I see. The left side has the "avidson" letters justified to the bottom of the D. The right side has those letters raised up and justified to the top of the D. Since these tanks are absolutely original paint does this scheme also follow for 1917?
          • 6029
          You are absolutely correct, jdonaldson. It looks like that oddity ended in 1916. In looking at the pictures I've collected, it appears that H-D did that so they could center the decal within the tank and border striping but due to the rocker arm cut-outs in the right side tank they had to raise the 'avidson' letters to the top of the capital 'D'. However, they seemed to be inconsistent with those decals in a number of years up to 1916. But, it looks like the 1917 and later H-Ds used identical decals and just pushed the right side decal up to clear the cut-out. My hat is off to you J.D. You have a good eye and I apologize for questioning your observation. This is another example of internal factory knowledge that is probably lost to time, but can be seen in careful observation as you have shown.
          • jdonaldson
            • May 2012
            • 29
            At the risk of exposing my denseness, I'm still not clear on which you think appropriate for the 1917, elevated "avidson" or not?
            Thanks for your patience!
            Jim Donaldson
              • 6029
              It looks like 1917 and later used the elevated 'avidson' script. It's funny how I'll re-read what I write numerous times and think, that sounds good, and then 2 hours later I'll read it again and think, that's just dumb Sorry for the confusion, JIm.
              • Tommo
                • Sep 2001
                • 1320
                This interested me and a look in the 1917 Sales Brochure shows the right side with the raised and the left side with the lower script.
                To me it appears that those original paint tanks you posted pictures of in your first post are factory correct if you believe what you see in that factory brochure.
                I have yet to figure out how to post pictures on this new site so sorry no pictures from the 17 Sales Brochure.
                Maybe someone that has a 17 Brochure and is more computer savvy than me can put the appropriate photos up.
                Peter Thomson, a.k.a. Tommo
                A.M.C.A. # 2777
                • Tommo
                  • Sep 2001
                  • 1320
                  Trying to attach pictures from the 17 sales brochure 1917 HD right side0001.jpg1917 HD left side0001.jpg
                  A.M.C.A. # 2777
                  • Tommo
                    • Sep 2001
                    • 1320
                    Wow it worked.
                    Maybe I'm not too old to learn
                    A.M.C.A. # 2777
                    • jdonaldson
                      • May 2012
                      • 29
                      Exeric, Tommo ... Thanks for all the help!
                        • 6029
                        Jim, I wish I could have been more help, but Peter came up with the perfect visual answer with the 1917 brochure. I did enjoy the research, and the hunt, and a concise conclusion.
                        • Tommo
                          • Sep 2001
                          • 1320
                          Wondering I went looking back a year to the 1916 HD sales brochure and found that both high and low style tank decals were used.
                          Low on both sides of a twin and high on both sides of a single so it appears that both styles of tank decals were available in 1916.
                          I've attached the appropriate photos out of the 1916 Sales Brochure.
                          Twin photos first first then single photos in the next post.
                          A.M.C.A. # 2777
                          • Tommo
                            • Sep 2001
                            • 1320
                            A.M.C.A. # 2777
                            • Tommo
                              • Sep 2001
                              • 1320
                              See what happens when the grandsons go home and are not there to supervise granddad.
                              Sorry about the varying image sizes
                              Give me time please and I'll get it right in the end.
                              A.M.C.A. # 2777
