Belly Numbers
  • aumick10
    • Nov 2018
    • 465
    Belly Numbers
    I have some J/JD cases that have different types of belly numbers.
    The earlier cases have two letters before the number sequence, while the later ones have a self explanetary two numbers for year stamped format.
    My question is do the earlier letter codes relate to any years that they were stamped, similar to transmission date stamping.
    • 5955
    I bet George Hood can answer that.
      • 2037
      I had 2 1915 J motors,early & late & the bottom numbers looked like different format from each other
      An early 1920s right case on my wall has B3 space 890 bottom number..my clock!
      • aumick10
        • Nov 2018
        • 465
        I have a set of cases labeled XO-xxx belly no, with a 25JD engine no.
        Also a drive case with a H4-xxx belly no and a 24JD engine no.
        • MMasa
          • 1192
          The number after the letter is a year code. It is the year in which the line bore number was STAMPED and could be a year earlier than the model year of the engine.
          Your X0 / 25JD case is a mystery. Can you post a pic of the vin and the line bore number?
          Is it a large base case? Does the vin look factory or like a re-stamp?
          Mark
          Mark Masa
          www.linkcycles.com
            • 2037
            Thanx Mark,I thought this was a 23 case
            • aumick10
              • Nov 2018
              • 465
              Mark
              Thanks mark, I will get a photo later today.
              • aumick10
                • Nov 2018
                • 465
                Here are some Photos of my 25JD cases.
                I suspect the X0 belly number is correct as a set of 1920 cases.
                The VIN no boss looks to have been removed at some stage and restamped, or it is a set of replacement cases that were stamped by the dealer.
                  • 5955
                  [QUOTE=aumick10;184764]Here are some Photos of my 25JD cases.
                  It is definitely a number job.
                  • aumick10
                    • Nov 2018
                    • 465
                    I though it was after I measured the cylinder studs. It is a small base case that I don't think existed in 20, If the XO is a 1920 belly no.
                    • MMasa
                      • 1192
                      The 25 VIN is NOT factory for sure. Also, ALL cases 1924 and up are large base.
                      The x is still a mystery as I've never seen a belly marking letter that high.
                      It looks factory but your picture is a bit blurry.
                      I'm going to say that it's a 1920 or 21 case that had the line bore markings stamped in 1920.
                      Mark
                      Mark Masa
                      www.linkcycles.com
                      • aumick10
                        • Nov 2018
                        • 465
                        I agree on the VIN.
                        The cases have matching belly no's X0-695.
                        They also have casting marks of 2-18W and 2-18A.
                        I am sure they are factory belly numbers.
                        • MMasa
                          • 1192
                          I agree, those are factory belly numbers. I've just never seen an X before.
                          Mark
                          Mark Masa
                          www.linkcycles.com
                          • aumick10
                            • Nov 2018
                            • 465
                            Thanks Mark.
                            Are you looking for contributions to your book?
