Transmission countershaft clearence in case
  • slamiste
    • Mar 2010
    • 260
    Began assembly of the transmission on the 1924 JD today. I assembled the countershaft gear with the roller bearings and hardened washers (2308-16) on each end. Fitting the assembly into the transmission case was difficult and with the countershaft installed I have no clearance between to countershaft gear and the mating pieces on either side of the case. The gear turns but I sure it's too tight. What clearance should I have? I assume that the only way to get the required clearance is to surface grind the 2308-16 washers or are washers of different thicknesses available?
    Sorry to have so many questions on this project but it's actually stating to come together. Bottom end of the engine is complete and the top end should go on in a week or so.
    Steve Slaminko
  • camsaure
    • Nov 2009
    • 135
    I can't remember which vender it was, sorry, but there are some out there in various thicknesses. They were in a set or assortment. Hopefully someone will chime in for you.
      I use free running to 0.0010" countershaft gear end float for the similar VL gearboxes. The standard 2308-16 is 0.080" thick, with new ones available in increments up to 0.100". If the countershaft assembly rotates freely then you're OK. If tight then a couple of thousandths off one washer on the surface grinder should fix it for you.
        Go here.
        Our custom work is designed from scratch. We offer manufacturing of OEM parts for a number of different classic bikes including Harley J, JD, UL, VL, Knucklehead, Panhead, Shovelhead, EVO, HD, Sportster, Springer, and that's JUST the Harleys. We also offer custom work designed and manufactured specifically for your customization or restoration needs.
        • slamiste
          • Mar 2010
          • 260
          Thanks everyone,
          I've ordered the washer kit from The Good Old Motorcycle Parts Company.
