For Tom, the beryllium copper looks like 1 mm thick nominal, say 0.037"
H-D Production IoE V-twins 1909-1929
For Tommo, here's a picture of the first aid box on a 1936 VLH Police bike. Looks familiar. Maybe Harley used a standard box and kept altering it for different model bikes. Box dimension is 7 1/2" x 5".Attached Files
Years back I had a nice OP tank top toolbox that I bought in a farm/estate sale thinking it would be a good first aid box candidate, but the latch system pointed out the age and the original finish made me pass it on to someone needing it.Robbie Knight Amca #2736
Thanks John and Tommo for posting fine factory pictures. Very interesting info on the variations of tank toolboxes.
if nothing else, this thread will have a collection of brochures and pictures of the factory's production twins in one thread.Last edited by Steve Swan; 12-11-2017, 12:19 PM.Steve Swan
27JD 11090 Restored
27JD 13514 aka "Frank"
on the frame, front down tube, what is purpose of that bracket held by 4 bolts and what appears a little lever with rod(s)....?Last edited by Steve Swan; 12-11-2017, 12:21 PM.Steve Swan
27JD 11090 Restored
After posting these pics of a 23, i won't post for a couple days or so.1923 LH.jpg1923.jpg
i don't have any decent pics of a 1924 model.
starting 1925 through 29, i have quite a few pics.Steve Swan
27JD 11090 Restored
yes, i see the lug pointing backwards now. and i see the rod going to compression release on gear cover. i've studied pics on earlier models, trying to see how the release is actuated, by hand somewhere on the frame? not like the 25-onward toe actuated models. did this rod/lever feature end with the '24 models?Originally posted by duffeycycles View PostBracket is front sidecar mount....backwards? The levers & rods are for compression release etcSteve Swan
27JD 11090 Restored
John, are you referring to the hand brake, or export brake, as it was known here in the U.S?Originally posted by TechNoir View PostIt is my understanding that 1920 is the last year of the separate front and rear brake in the USA (the front brake was an option in the USA) and in 1921 there was a rocker pedal so you could only use one at a time.
Also, as I mentioned a few pages previously, the UK models had the front brake and the front stand as standard whereas the front brake and front stand were an option in the USA. The rear rack was standard in the UK too, was it standard or an option in the USA?Last edited by exeric; 12-11-2017, 04:56 PM.Eric Smith
That is a bit confusing to us. Front Brake started in '28.
But hand brake option was much earlier
Thanks Duffey!Originally posted by duffeycycles View Postleft twist grip retards timing and opens the compression release on cam coverSteve Swan
27JD 11090 Restored
