H-D Production IoE V-twins 1909-1929
    • 8239
    #46
    [QUOTE=T. Cotten;166333]Great pic Eric!
    But photobucket phuckets with me if I try to view it any more closely, or save it.
    Its so easy to save to this forum direct!
    When you bring up the box to post your reply, look below it for a 'button' that says: Manage Attachments.
    Click on it, and a second browser tab appears. Somewhere in small print among all the bells and whistles it will say: Add Files.
    Click on that, and then look in the box that pops up for Basic Uploader.
    Clicking on that will change that box to say Browse.
    Clicking on that lets you pick your picture from your computer. Then click Upload.
    Click Done at the bottom when you are done, and it will close that tab, but the attachment will be listed on the first tab where you compose your text.
    Its way too many hoops to jump through, but its better than an expensive external host that will make you jump through its own hoops, and hold your photos hostage someday.
    Your browser may vary.
    PS: Late edit Folks,
    After a full day, Eric's PhotoBucket post works, and at a decent resolution!
    • Steve Swan
      Possessed by Motorcycles
      • Aug 2013
      • 1589
      #47
      Thanks for your reply, Eric. What amazes me with these early pioneers of the gas combustion engine era, they had to think all this stuff up; it didn't exist until they made their ideas reality. their ideas were based on their understanding of the laws of physics, mathematics, chemistry, general scientific and practical knowledge of the day. really remarkable. would have been a fascinating era to have lived in; transportation beginning it's transition from animal power to mechanical power. using a needle valve to control oil d.p.m. is ingeniously simple and works perfectly under controlled conditions with no variables.
      hopefully members who own these early machines will share what they know or others who have direct knowledge and/or other pictures will contribute. that would really be nice !
      i've got a copy Victor Page's "Early Motorcycles" and have read here and there in it from time to time. i see no mention of the Sagher type spring fork nor does an internet search shed light. it would be really nice to hear more from more people.
      moving on, going back to pictures i posted from the internet of the 1911 twin. i believe model designation "7D" ? was this the first year for a model designation on the twins ? also the first year the twin was referred to as "the silent grey fellow" ? Hatfield's book mentions the '11 twin had mechanical inlet valves; was this the first year for mechanical inlet valves ?
      a forum member by name of "silent grey fellow" posted earlier; maybe he'll contribute, assuming he knows about anything about these machines.
      Steve Swan
      27JD 11090 Restored
      27JD 13514 aka "Frank"
        • 6029
        #48
        It has always been my understanding that the 1911 H-D twin had mechanical intake valves, but looking at the above illustration, you'll notice that rendering shows atmospheric valves, and that makes me believe that drawing is of a earlier H-D twin design. Odd that H-D would allow an early design to muddy the water before the introduction of their improved 1911 twin.
        • Steve Swan
          • Aug 2013
          • 1589
          #49
          maybe something as simple as "Motorcycle Illustrated" didn't have anything to go by for showing the new mechanical inlet valve design...?
          Steve Swan
          27JD 11090 Restored
            • 8239
            #50
            I hate to stick my head up for abuse, and ask any more questions, but,...
            Can anyone tell me the obvious differences from a J transmission and a later V model?
            An associate just showed up with a prize from a meet, and I hope he's right that its early.
            Thanks in advance Folks, because chassis are out of my zodiac,...
              • 6029
              #51
              That transmission went through many variations, and changes, Tom. The profound difference between early and late is; the shifter escapement. Early trans has a rotating clutch release shaft that runs across the top of trans, late uses the more conventional lever type clutch release arm (like knucks, and pans). Unfortunately, late JD, and early VL transmissions are very similar, but my trans knowledge is limited to early Js and I'll only embarrass myself if I try to elaborate
              • Steve Swan
                • Aug 2013
                • 1589
                #52
                We need Mark Masa ! (somewhere, in the past few months, i seem to recall there being a post asking diffs between jd & vl trans....)
                Steve Swan
                27JD 11090 Restored
                • Tommo
                  • Sep 2001
                  • 1320
                  #53
                  Here's 3 pages out of 1913 MOTOR CYCLE magazines that cover the 1913 HD parcel delivery trike and details of the 1914 models.
                  I thought they might add some facts to this thread.
                  As for the VL gearbox the easiest id feature is the two ears on the drive end of the gearcase that mounts the inner chaincase.
                  You may find VL gearboxes that have been fitted to J models with these ears cut off.
                  If the clutch is fitted it will have a duplex sprocket and the main internal change is that the mainshaft no longer has a split brass bush for the final drive gear to turn on.
                  This is a very basic way to tell the difference between the two.
                  Peter Thomson, a.k.a. Tommo
                  A.M.C.A. # 2777
                  • Steve Swan
                    • Aug 2013
                    • 1589
                    #54
                    Tommo, thanks for joining in ! Those are great articles, i really enjoyed reading them. It enjoyed reading about the pedal start and braking system. These bikes were the true bicycle framed motorcycles.
                    Steve Swan
                    27JD 11090 Restored
                    • Steve Swan
                      • Aug 2013
                      • 1589
                      #55
                      Hopefully we'll hear more about the '07 - '11 "doubles." Moving along, here's 5 pics i found on the internet of 1912. a couple are somewhat large and better view can be obtained.
                      well, turns out what i can see of these pics on my computer is not what shows up when i download them in to our website. so, not as large or closeup as i had hoped.
                      Steve Swan
                      27JD 11090 Restored
                        • 8239
                        #56
                        I appreciate the transmission replies, Folks,..
                        But I still wouldn't be able to tell the difference, and the fellow left with the box before I could make my camera's 'dumb' card 'smart' again.
                        And I appreciate your pics Steve, as I am still trying to figure out the various positions for the Schebler HX bowl. It appears that Js have the bowl cap directly under the airvalve, which doesn't seem convenient to me.
                        PS: A fellow at D-port (sorry for my 'name block') told me that "H" models became "HX" when threaded manifold attachments were replaced with flanges.
                        Should I revise my notes? Thanks again in advance...
                        • Steve Swan
                          • Aug 2013
                          • 1589
                          #57
                          Thanks Tom, I'm glad you're "in" this thread !
                          fwiw, i googled "original 1911 Harley Davidson." this is what i found. (some of the pics actually enlarge pretty nicely.) and of course i realize anything we see on the internet may not be accurate or even real. but i found these pics, purportedly of 1909 model, could be of interest.... I've never been to the factory museum, so i don't know what machines the factory has representative of each/every year of production. Or if a person can get good pics of machines displayed at the museum.
                          now what's hilarious about finding "information" on websites (actually disinformation) is the picture below, purported to be the "1911 Harley-Davidson V-twin motor with improved valve train." Even i know this is a 1927 engine; appears could be a factory picture. (pretty scary to think some people may believe what they read or see on internet is "true.")
                          fwiw, here is the link to 1909 information - https://rideapart.com/articles/birth...n-v-twin-motor
                          Steve Swan
                          27JD 11090 Restored
                            • 8239
                            #58
                            Wow, a manifold support!
                            Makes too much sense.
                            Thanks again for saving my 'data usage', Steve!
                              • 6029
                              #59
                              Okay, I'm confused, Steve. That '11 is obviously the twin that Harley-Davidson owns and it's an early atmospheric intake motor. I've never questioned this bike until you brought all this up, Steve I do know there is controversy about this motorcycle in regards to no belt tensioner, and obvious tool room made parts. I know we have members that could give a detailed background on this bike, and the history of Harley's early doubles. I guess I could also read Herbert Wagner's superlative book on early H-D history
                                • 6029
                                #60
                                Also, look at a copy of Herbert Wagner's "Classic Harley-Davidson 1903-1041". There are good pictures of Bruce Linsday's restored 1911 double and we all know Bruce knows what he's doing.
