1927 J Model manual
  • ChrisLewis
    • Aug 2015
    • 82
    1927 J Model manual
    Hello
    I purchased a J model last year. looked good but turned out to be a disaster, worse than owning a boat !
    A typical issue is when I took the forks apart only one tube had the guide.
    cracked valves, cracked cylinder, bad gear box etc.
    STILL I am determined to build it correctly, may not be cosmetically correct but the engine and box I intend to get perfect.
    JD Jugs for a start ! the wait was worth it as they are top quality and well recommended.
    My question is where can I find a manual, I have the shop dope but really need to know what should be there.
    An example would be the fork guide if both had been missing I would not have known any difference, and possibly assembled the bike without them.
    Anybody help ?
    looked for something suitable in the library but to no avail.
    Regards
    Chris (England)
  • Steve Swan
    Possessed by Motorcycles
    • Aug 2013
    • 1589
    Chris, i imagine you've seen my restoration thread 27JD. And John Brooke's 20J thread.
    JD Yahoo Groups has various manual downloads under "Files." imho, jd yaho groups is a "must join." There's guys there that rarely or never come to amca or caimag.
    scrEamBay has literature time to time.
    I couldn't have made it without 22-26, 22-27 and 22-31 parts books. I studied them for hours, contrasting, comparing information i was reading, asking questions, making notes, etc.
    1918 "motorcycle repairman's manual" and 1923 "u.s. army manual" also helpful.
    Type in Harley Davidson "F" head engine," i found very helpful info there. Rebuilt my transmission using info therein. and sage words on pinion/setup clearance.
    And, Rider's Handbook very good.
    I couldn't be at my current stage of progress without getting to know fellows from jd yahoo and amca forums, receiving the help of some really very experienced, knowledgeable and passionate JD enthusiasts.
    I did as much if my own work as i could, but certain things i don't have equipment for, so the help i received was invaluable.
    Research, study and ask questions.
    If you can't find the info you need to purchase or download, i can make copies.
    Steve Swan
    27JD 11090 Restored
    27JD 13514 aka "Frank"
    • TechNoir
      • Dec 2015
      • 301
      Re: 1927 J Model manual
      Chris,
      Sage words from Steve.
      The 2 manuals that Steve mentions I have on a shared dropbox folder. PM me your email address and I will make them available to you.
      I got my parts book from a USA ebay seller, I would think that the 27 book should be available on ebay or one of the J/JD suppliers such as Replicant Metals who have some advertised on their "Library" page.
      John
      • ChrisLewis
        • Aug 2015
        • 82
        Steve
        Thank you, I will take your advice and follow up these leads.
        Watched your u tube clip and was amazed that you also ride holding the handlebars just off the grips, funny I tend to do that also !
        I appreciate that restoring one of these in the States is hard but here in the UK it is near impossible, I went to the UK's largest swap meet and despite searching all day the only thing I found was a rack that was beyond repair.
        Am currently looking to fit a hand clutch lever as we have a lot of hills and need my right foot on the brake to stop me rolling backwards so very difficult operating the clutch, I have found a lever but no linkeage, any diagrams would be appreciated. chris@cssurvey.co.uk
        Thanks again Steve
        Chris
        • ChrisLewis
          • Aug 2015
          • 82
          John
          Thanks very much the manuals would be greatly appreciated, chris@cssurvey.co.uk
          Will continue searching for the parts books as mentioned by Steve.
          Thanks again
          Chris
            • 5955
            Look here.
            http://antiquemotorcycle.org/virtual...3a&max=1000000
            • ChrisLewis
              • Aug 2015
              • 82
              thanks Chris
              • ChrisLewis
                • Aug 2015
                • 82
                Valuable information from members
                I would like to thank the members who have contacted me
                Firstly my problem was starting on a hill with no front brake and my right foot on the brake.
                My initial thought was a hand clutch lever, but have been advised that they are not recommended.
                And then out of the blue I find out the European model has an inner and outer rear brake !!
                The one I purchased only had the outer, problem solved !
                now all I have to do is find the correct parts.
                So thanks guys, makes it worth being a member.
