1916 harley J- starter pedal?
That looks like a bicycle pedal that someone has put onto the standard pedal shaft.
That is NOT the 1916 only kicker pedal.
MarkMark Masa
www.linkcycles.com
The parts you have circled are correct. There is a picture in the book "the big book of Harley Davidson" that shows the factory assembly line where they are putting together what look to be late 1916 or very early 1917 models and the large single block kicker rubbers are clearly visible.
MarkMark Masa
www.linkcycles.com
Right, I took the picture from a German Magazine (Oldtimer Markt) - they had an article about a 16F some years ago- restored to former glory. I think I will go for the normal pedal on mine then as it seems there are no reproductions to be found for the 1916 single pedal style
