What is the prescribed method for removing the generator drive gear 632-18 ?
JD Generator Gear Removal
Steve Swan
27JD 11090 Restored
27JD 13514 aka "Frank"
https://www.youtube.com/watch?v=bwlIsZKmsTYTags: None
Thanks for your replies. If you could share pictures of the pullers, i'd appreciate it.Steve Swan
27JD 11090 Restored
Here's the genuine H.D. one that as well as the generator gear also pulls off the half time pinion.
It's had a hard life and at some stage has had a 3/8 bolt put into it.
Originally it would have been 5/16.
It' 8.00 am Xmas morning here so Merry Xmas and a Prosperous New Year to one and all.Attached FilesPeter Thomson, a.k.a. Tommo
A.M.C.A. # 2777
Thank you for the picture. When you say half time pinion, are you referring to the keyed gear on pinion shaft?Steve Swan
27JD 11090 Restored
Bob, can that puller be purchased as a new part and if so, from who ? I'd like to purchase one if they are available. Thanks in advance. SteveSteve Swan
27JD 11090 Restored
Steve
The gear on the timing side mainshaft that drives the timing gear train which we, over here, have always called the "half time pinion".
It's what our tutors always called it so its just a thing that has stuck from all those years ago.
Its like the car/truck gearbox thing. Spigot shaft, first motion shaft, input shaft. 3 names for the same thing so I'm sorry if I confused things by calling it the Half Time Pinion but its just the way I was taught.Peter Thomson, a.k.a. Tommo
A.M.C.A. # 2777
Oh! No prob! I appreciate your reply. I just wanted to make sure i thought i knew what you were referring to.Originally posted by Tommo View PostSteve
Its like the car/truck gearbox thing. Spigot shaft, first motion shaft, input shaft. 3 names for the same thing so I'm sorry if I confused things by calling it the Half Time Pinion but its just the way I was taught.Steve Swan
27JD 11090 Restored
