Monroe Shock
    • Feb 2003
    • 5353
    Monroe Shock
    Have any of you folks ever been into one of these? Or could someone tell me what kind of resistance one should expect? It seems that it could be a little stiffer.
    Cory Othen
    Membership#10953
    • 5952
    [QUOTE=c.o.;107113]Have any of you folks ever been into one of these? Or could someone tell me what kind of resistance one should expect? It seems that it could be a little stiffer.
    It probably was stiffer when it was made back in the '40's. There are guys who advertize in Hemmings Motor News who rebuild shocks.
      • Feb 2003
      • 5353
      Thanks for the heads up Chris. There isn't much to it and I thought perhaps someone here may have tackled the job. I'll check out Hemmings though if I can't figure it out.
      Cory Othen
      Membership#10953
        • 4785
        Cory,
        Be aware that the travel was quite short. Pump it a few times and see if it stiffens up any. The resistance is on the return, not the compression. Springers only have about 2 inches of working travel and most of the time only move about an inch or so. It is merely a damper to slow down spring oscillation so is not very stiff!
        Robbie
          • Feb 2003
          • 5353
          I was waiting for you to weigh in on this Robbie! You've cleared it all up for me and I do believe it's good to run as is!!! Thanks!!
          Cory Othen
          Membership#10953
            • 4785
            Cory,
            to expound on the subject! They were poor at best when new. Many years ago i was in an old dealers ( a friend of mine) and found an NOS shock hanging in the rafters. Of course i wanted it right away! When i asked him about it his response was "well, we took them all off when new and threw them away because they were ****. But since you want it , it is going to cost you", well, he charged me 5 bucks and we were both happy!
            Robbie
              "spring oscillation"
              I got to talk to the old ladie about this.
                • Feb 2003
                • 5353
                Robbie,
                Five bucks eh? Not bad!! I've got the ride control set-up on my pan now but in the pursuit of purity I thought I'd grab a shock. I'm scratching my head now though as that darn ride control is dialed in nicely and the front-end is smooth!!! Thanks again for the help!!!
                Cory Othen
                Membership#10953
                  • Feb 2003
                  • 5353
                  Bob!!! I never tire of your comments....
                  Cory Othen
                  Membership#10953
                    $5 clams! There was a guy on Fleese-Bay a month ago that had his reserve set $1000.00 for a NOS OEM. It didn't sell but damm close. He told me he had two more.
                    • Rollo
                      • Nov 2008
                      • 599
                      Paul Friebus at American Cycle Fabrication told me that he can rebuild them. I don't think these come apart like what we are used to in a car or regular motorcycle shock. That is why a lot of guys pitched them when they were worn out and put a ride control on there. I can tell you the repop ones suck and leak ( messing up the fender on my 47 knuckle) so I try to get originals when I can find them reasonably priced and working.
                      Tom (Rollo) Hardy
                      AMCA # 12766
                        • Feb 2003
                        • 5353
                        Thanks for the lead Tom. You've also echoed everything I've heard about the repop shocks. Real parts if even somewhat worn seem to be much better.
                        Cory Othen
                        Membership#10953
