!910 Engine Boost?
  • wyatt emp
    • Nov 2010
    • 163
    I will, and I do feel better now. I was actualy wondering about the valve spring as I saw a vidio on Yutube, where a guy named Indian Jeff had a 1912 with simular engine, where he added another spring to the one already there, I assumed to add tension. He did have the two speed rear hub but he was on the freeway with his.
      • Feb 2003
      • 5353
      Jeff was famous for blasting around Seattle on that '12. He believed in riding them that's for sure!
      Cory Othen
      Membership#10953
      • wyatt emp
        • Nov 2010
        • 163
        Did you know him? Looks like it was some time ago, then I saw a video of him being arrested by police and then a latter one where he was in a wheelchair???? Anyway not to get off topic I know we were joking about AV fuel but what about some kind of additive like octain booster?
        • wyatt emp
          • Nov 2010
          • 163
          Tommo: There does appear to be a possible air leek in the carb around the throttle valve as when I turn it out when the motor is running some fuel will spurt out. Is this a possible problem?
          • Tommo
            • Sep 2001
            • 1321
            When it comes to setting AIV spring tension there is a very fine line between too little and too much.
            Too much and the inlet valve is slow opening and therefore doesn't get a full charge into the cylinder and with too little tension the valve is slow closing and some of the charge gets blown back out the inlet valve.
            One's as bad as the other and there's no easy answer as how to achieve that magical correct tension as each and every engine is slightly different and therefore requires a setting that suits that particular engine.
            Your valves and seats must also be in perfect condition and the inlet valve seat should be as narrow as possible. Wide seats hinder the flow of the incoming gases and result in a considerable drop in power.
            Near enough in this situation is not good enough and it's a bit like tuning a piano, to be right it's got to be spot on.
            Peter Thomson, a.k.a. Tommo
            A.M.C.A. # 2777
            • Tommo
              • Sep 2001
              • 1321
              Sorry Wyatt I didn't answer you question.
              It could be a carb problem but it could also be a spring tension problem as I outlined in the above reply.
              Too little tension and the valve doesn't shut quick enough and some of the charge is blown back through the carb.
              A.M.C.A. # 2777
              • wyatt emp
                • Nov 2010
                • 163
                The guy that rebuilt it knew what he was doing so probably where it should be. He even replaced the babit bearing with bronze. I am running regular unleaded gas in it. Would it run better on premium or with an octain boost additive?
                • Tommo
                  • Sep 2001
                  • 1321
                  I put about a pint of Av gas to every gallon of 91 grade gas I use here in NZ but this is done as a lead addittive rather than for any performance gain.
                  Someone over there should be able to give you better advice on this subject but with valve recession in mind I'd be looking to try and get some lead into the fuel to help with valve seat life.
                  A.M.C.A. # 2777
                  • rwm
                    • Dec 2006
                    • 1302
                    how high above sea level is acton ca?
                    rob ronky #10507
                    www.diamondhorsevalley.com
                      Acton varies from 2500 to 4000 feet.
                      • rwm
                        • Dec 2006
                        • 1302
                        what dose that do to an atmospheric valve?
                        rob ronky #10507
                        • Tommo
                          • Sep 2001
                          • 1321
                          #27
                          Rob I could see this coming and was just willing you not to ask that question.
                          In short it just complicates the issue being discussed.
                          Set the tension for the best performance at the altitude you most ride the bike at and be prepared to suffer the consequences when you ride at significantly different altitudes.
                          A.M.C.A. # 2777
                          • wyatt emp
                            • Nov 2010
                            • 163
                            #28
                            I did find that I would loose compression while under way and that by pushing down on the valve and spring a couple of times would fix the problem. Assuming a stronger spring might do the trick, I replaced it with one and gained the power I need. Atmospheric conditions or just a weak spring, who knows? Inertesting thoe......
                              • Feb 2003
                              • 5353
                              #29
                              Great to hear! I assume now that you can make it to the top of your drive-way?
                              Cory Othen
                              Membership#10953
                              • wyatt emp
                                • Nov 2010
                                • 163
                                #30
                                That is correct.
