Peashooters, Schebler AMX, Linkert MR1&2 race carbs
  • Motorviking
    • Jun 2022
    • 30
    This gallery has 4 photos.
    • Motorviking
      • Jun 2022
      • 30
      AMX13 as fitted to Indian - model number stamped at air horn end!
        • 8248
        I had to enhance your pic a bit, Motorviking!
        And here's another to compare:
        (Note no serifs on A, no base on 1)
        So we must wonder what variation the A denoted.
        The little 8 on your AMX13 is the size I usually call 'inspection' stampings...
        (AMX 8 stamped behind flange.)
        We may never know..
          • 8248
          Here are what I call 'inspection' stampings on potmetal models,
          (Two different DLX113s, both stamped upon bottom of manifold flange...)
          • Motorviking
            • Jun 2022
            • 30
            Description of AMX12A
            • Motorviking
              • Jun 2022
              • 30
              Not sure if you have seen this list on Indian carburettors
                • 8248
                Alcohol makes sense, Motorviking!
                I remember that listing when it was Indianmotorbikes.com.
                The format is new, but it still has the same old errors (like "M351", etc.)
                Back to barrels, the idle needle from an AMX-12A proves to me I have no clue how the carbs operate:
                And I really wonder about the modern reproductions...
                PS: So how do any of these bolt up to an HD single?
                  • 8248
                  Although it was usually on the bottom of the flange,...
                  I have also found "serial" stampings on a DLX88, but it was on the side of the flange,
                  And to further confuse the catalog bowl offering, here's a bronze bowl for potmetal DLXs with a 'lid':
                  Was it just whacked that way?
                  • Motorviking
                    • Jun 2022
                    • 30
                    This gallery has 1 photos.
                      • 8248
                      I'm still confused, Motorviking,...
                      The flange upon the cylinder casting that the adapter bolts to is horizontal, whereas the flanges on GX models (as shown in #6) are at an angle.
                      The adapter in your pic reminds me of one for a Hen, which was horizontal:
                      Or this one...
                      Did HD GXs bolt to an adapter?
                      • Motorviking
                        • Jun 2022
                        • 30
                        I believe the GX-4 bolts directly to 10-26 (diagonal).
                        To fit AMX12 - there is a flange/manifold to change diagonal 2 bolt to straight 3 bolt. 9BE5574B-3CC2-40B4-BD9C-294AA07FDE5F.jpeg1EDAAFF0-38A3-4A4E-B6A9-8BD4EE371CE3.jpeg
                        • Motorviking
                          • Jun 2022
                          • 30
                          #27
                            • 8248
                            #28
                            The adapter is what I expected, Motorviking, Thanks!
                            But the long intake on the casting throws me, as none of the vintage pics I've snagged show it, so far... (Joe's knee is usually in the way...)
                            I see it upon your head in your conversion-to-OHV thread, but cannot tell if it is removeable; Its hard to imagine it was cast that way (but its easy to imagine taking a hacksaw to it, if it was.)
                            • Motorviking
                              • Jun 2022
                              • 30
                              #29
                              Cast like that!
                              • Motorviking
                                • Jun 2022
                                • 30
                                #30
                                Head 10-27 used adaptor 2 bolt (horizonal) to 3 bolt
