Right hand tank shift
  • len dowe
    • Oct 2002
    • 520
    There are companies that make system's designed for paraplegics. It runs on pneumatic.
    AMCA #765
    • ryan
      • Mar 2017
      • 610
      I am not sure if a ratchet top can be used with a 3R tranny. I am not sure if the 3R shifter drum will work in ratchet top? Those are my concerns.
      • ryan
        • Mar 2017
        • 610
        When a friend lost the use of his legs he dreamed up a combination of H-D parts to modify the bike so he could ride it. First was to install a tank shift lid on the gearbox. Second was to get a left hand tank shift tank and all the shifting linkage. Once all of that was put on the bike he used a section of handlebar with a plug in one end. He drilled and tapped the plug and screwed it on the shift lever in place of the ball. He put a hand grip on it and attached the hand clutch lever to it. So now he can clutch and shift with the same hand.
        He used a V Rod hydraulic hand clutch lever master cylinder to activate the rear brake.
        All H-D parts and the only thing that got cut was an old handlebar.
        Thanks for your reply, I kind of thought the same way and taking that approach. My only thought on that was to use either a mousetrap or a mousetrap eliminater. Leaning toward a mousetrap on this whole setup.
        Thanks again!
          • 4785
          A friend built a footshift 3&R for his bike years ago. He made up a custom shift drum from parts of both. It worked great. The bike was actually an endurance event bike and he used the reverse to back out of bad situations. Anything is possible.
