28' JD exhaust guides
  • Bro74
    • Apr 2013
    • 23
    Do any of ya'll know what would be a good insert or replacement guide the 28' JD exhaust guides? It looks like mine are cast in and cracked in 5 places in the exhaust port.
    RT
    • 2024
    Some of the JD's on the cannonball were running valve guides made out of used Harley twin cam guides. Jerry
    • Bro74
      • Apr 2013
      • 23
      Thanks Jerry, I'll look around and see what I can come up with.
      Rowdy
        • 2024
        Rowdy I guess you have to machine on all dimensions but the real advantage is that they are cheap and will run without lubrication or at least not much. I sent you a PM.
        Jerry
        • Runnlo
          • May 2010
          • 34
          Good morning to all,
          A friend of mine found a 1928 JDL. My question is ....did harley make a 1928 JDL factory racer, and where can I find some pics of it.
          I'm just trying to help a friend. I found some pics of a 1928 JDL sport solo, but none of a factory racer. any help would be greatly appreciated.
          Stan.........................runnlo
          • NUMO
            • Aug 2008
            • 19
            Rowdy,
            Here is a link to the guides that I use. I have been using them for year with no problems. They are $7.00 each, but you can cut one in half to make two guides.
            Hope this helps.
            Numo
