Mystery Oil Pump Drive Gear
  • Mystery Oil Pump Drive Gear
    I have this oil pump drive gear that I need some help to ID.
    It is similar to a JDH oil pump drive gear (relieved on the back side) but has too many teeth.
    On the left is the gear for a 1928/29 Two Cam. It has 39 teeth.
    On the right is the mystery gear. It has 43 teeth.
    At first, I thought that it was for a single but the picture in the parts book for that gear (622-26) has 55 teeth by my count. The mystery gear is bushed like the single ones were. Was there another style of single gear?
    Mark Masa
    Mark Masa
    www.linkcycles.com
    Mark, I sent you an e-mail.
    Ken
    Ken S., # 6457
    1926- H-D BAF-Peashooter
    1954-H-D Panhead
      Could it be from a Peashooter??
      Cory Othen
      Membership#10953
        Cory,
        Good guess! 43 tooth fits 26-28 magneto model singles,the generator gear is around 54 tooth, I currently have 1 from the late Don Berta,he was taking 54 tooth and remachining down to 43,this was the only part I did not have correct inside.
        Ken
        Ken S., # 6457
        1954-H-D Panhead
          SANY1623.JPGSANY1624.JPGGuy's
          So you can see the differance,between a made gear and an original.
          Ken S., # 6457
          1954-H-D Panhead
            Ken I was just going on a hunch seeing as you replied to the thread... I learned sumthin' though and that's always good!
            Cory Othen
            Membership#10953
              Hi, i am looking for a gear like that, 43 teeth. Can anyone help?
              I also have a similar, but 47 teeth. Does anyone now what bike it fits?
              Regards Lars
                Originally posted by milw.pirates View Post
                [ATTACH=CONFIG]10502[/ATTACH][ATTACH=CONFIG]10503[/ATTACH]Guy's
                did you run the one you had made up?
                rob ronky #10507
                www.diamondhorsevalley.com
                  No I never ran motor with this gear
                  Ken S., # 6457
                  1954-H-D Panhead
