J Pistons
    • 2024
    J Pistons
    How far can a late 61" J cylinder be bored and where can pistons be found? Jerry
    • 6018
    Great question Jerry. My front cylinder is rust pitted and I need pistons as well. I recall Matt Walksler stating on another forum that he used flathead Ford pistons in his 61". Does anyone know if Ford pistons are viable replacement?
      • 2024
      My rear is used at +.100" and the piston has no markings and I am not really familiar with J's. Front is used at standard.
      • dlm32
        • Jul 2009
        • 110
        Think you can use UL Pistons or get higher compression pistons from Competition Distributing. Check the Yahoo harley j/jd group. There's a long post on using UL pistons. The J/JDs had a taper ground bore(tighter at the top than the bottom.). The cylinders need to be straight bored to use more modern pistons.
        David Morrill
        Sylacauga, AL. USA.
        AMCA #15284
        Deadly Dave's Blog
        Sharing the Lost Stories of Early American Motorcycling.
        http://dlmracing.blogspot.com/
        1921 Harley-Davidson Model J Racer
        It will break a hundred, if you drop it from a plane!
          • 2024
          David That stuff all works for JD but I do not think J. Competition has only 74" pistons on their website - no 61's. I am going to call them and see. Their pistons I think are made by Venolia.
          Jerry
          • Tommo
            • Sep 2001
            • 1320
            I use 214 cu in Bedford truck pistons.
            There is a Mitsubishi piston that a lot of guys use and it raises the com a bit.
            If you want to know exactly which Mitsi piston I'll have to ask around for details.
            Bedford pistons go straight in with no mods needed. Maybe there's a Chev equivilant as they are both GM products.
            Don't get too carried away with your overbore size as you wouldn't be the first person to end up with a detachable head cylinder.
            Peter Thomson, a.k.a. Tommo
            A.M.C.A. # 2777
            • bill campbell
              • Jan 2009
              • 129
              flathead piston
              hey Jerry I may have a stash of n.o.s. flat head piston's at the old house, I will be stopping by later today and I will see whats left.
              • MMasa
                • 1192
                Tommo
                I'd be interested in the part numbers of the Bedford truck piston as well as the Mits.
                Mark
                Mark Masa
                www.linkcycles.com
                • Tommo
                  • Sep 2001
                  • 1320
                  Mark
                  The Hepolite number for the Bedford pistons is 10171
                  As soon as I find out the Mitsi details I'll let you know.
                  A.M.C.A. # 2777
                    • 2024
                    Tommo Have you found out anything more on the pistons. I tried searching for your numbers but could not really come up with much.
                    Jerry
