22JD Tear down!
  • CeesV
    • May 2017
    • 7
    #61
    I am restoring a 1922J model and are looking for a battery case, either a
    replica or somebody who could show me a picture with hopefully some accurate seizes. Could you help me?
      #62
      Cees, we will have these battery boxes to market in three weeks and like all the parts we make. It will be exact to the original. These would have been done already but we blew a cylinder on our press brake that had to be made. Robert Luland
        • 6008
        #63
        Bob, what is the year span on those battery cases?
          #64
          Eric it would be 1915-23. Bob Luland
          • CeesV
            • May 2017
            • 7
            #65
            Battery case for HD1922j
            Thanks Robert, let me know when it is available. Do you ship to the Netherlands?
            The box has a stud at the rear mounted on the reinforcement strip, also the lid has two screws (for finger tighting) and on the front a terminal strip, you will have the case that complete? I can provide some pictures if you like
              #66
              Like stated, the box will be indistinguishable from the original. Yes, we ship all over the world. Go to our website http://www.thegoodoldmotorcyclepartscompany.com
              • CeesV
                • May 2017
                • 7
                #67
                Hi Robert see pictures from the box
                  #68
                  Man, what I would do to have that sidecar plug to copy. I learned something. Didn't realize the thumb screws on the battery box lid were nickle plated. We just left them polished bronze. Bob L
                  • CeesV
                    • May 2017
                    • 7
                    #69
                    Yep,
                    The pictures were taken from a fully restored 1922 with a 100% AMCA score.
                    I am still looking for the braces for the headlight part number 4973-20 , something a lot of experienced fellows do not even know that it did exist. Let me know if you have them.
                    Also I am still looking for a headlamp. part number 4901-20. I learned that Replicants is starting to make a series
                    Are you still making the complete battery case as per pictures ? If yes let me know when it is ready and I get one from you.
                    With best regards
                      #70
                      Only one problem, that's a 1923. See three pin strips on fender? See ignition switch. not 22. Beautiful bike though. Bob L
                      • CeesV
                        • May 2017
                        • 7
                        #71
                        Perfect knowledge, you are spot on it is a 1923!! Apology my typing error.
                        Parts I am looking for is for my 1922J, and are identical to the 1923, the main switch and fuse box is not 100% clear to me, was it used on 1922 Y/N? part number 4505-22 refers to 1922 late and all 1923 the -24 was used on 1924, but the fuse box is definitely larger, correct?
                          #72
                          1920-most of 22 used 4510-20. Fuse box only (See pictures). You didn't need a switch as the generator had a centrifugal switch built into it. Most people just put a diode under the cover. Very late 22 and all of 23 used the manual switch with the fuse box part 4505-22 (Your pictures). 24 and 25 used 4505-24. I can't to begin to tell you the difference between 23 and 24. Bob L
                          • CeesV
                            • May 2017
                            • 7
                            #73
                            Thanks for the pictures Robert, the 4510-20 on the picture are they offered still? It looks like NOS.
                              #74
                              There not offered but the one in the picture is nos. I might do a run of these next year. Lots of little parts makes it a pain in the ass. Bob L
                              • Tommo
                                • Sep 2001
                                • 1320
                                #75
                                The bases tell you.
                                If you look at the attachment you will see that 1323 has a round base for the fuse box and 1324 has a projection out the side that took a Bakelite, 2 piece block that supported the wires.
                                From the HD parts book;
                                1323 KK342 Mounting plate assembly Later 1922, all 1923.
                                1324 MK342 Mounting plate assembly All 1924 and 1925
                                Peter Thomson, a.k.a. Tommo
                                A.M.C.A. # 2777
